Corner Editor makes shape disappear
I was trying to round some corners on a mask shape I had made, but when I did so, the shape itself disappeared: here is the video. I can send the file if that helps
@Boldline Send me the file.
@vectoradmin Just sent it. After sending, I tried drawing a rectangle shape to test the issue out further and as I was dragging it, VS shut down on me. Not sure if that was my machine's fault or what...
UPDATE: After I restarted VS, I opened a new fresh file and made a shape from scratch and used the round corner tool without any issues. It worked as expected. I then reopened the file I had troubles with and tried on that mask again and it did not work - giving me the same issue as before.
I again made a new rectangle shape to test and again VS shut down on me...
What did I do wrong with that mask shape that causes it to have issue with the rounded corner tool and then shit down when drawing a shape?
@Boldline Replicated, but without the crashes.
It seems to be a bug in VS that causes the corner problems when there are some stray nodes. Cleaning up the stray nodes should work around the bug.
@Boldline Using corners in shapes with stray points (and segments) is fixed in build 1.0.052
