Object suddenly disappear
Hi. Happens with some other objects, but i can document this. A given image, with some fx applied in this case, after move it trough the screen, suddenly disappear. Im not sure if is a gesture, or a bug, but it disappear. Ctrl Z make it appear again. In this case it took some time to get the object disappear, you can see what happens at the end of the video, but in other cases it happens sooner.
https://drive.google.com/file/d/1_FgkHUbJ92rsEi43aCQPT9XO0FWpKItg/view?usp=sharing
@marce I will try to replicate this
I have had something similar happen recently, when either moving or in some cases scaling an imported image the image flies off the screen in some direction or another and never comes back. Seems like something during the transform causes the image to transform out of view.
Command+Z brings it back for me also, whatever it is can be undone. Sometimes when I was scaling one I found that for some particular object I could get it to happen repeatedly when scaling from one corner (I think it was usually the upper right corner) but if I switched to a different corner (upper left?) it scaled as expected.
I don't have an example I can share, but maybe that description gives a clue?
