Swirling Lines Tool: large amounts of nodes after breaking apart.
  • Hi,
    Not sure if this belongs in the Bugs section, if not, feel free to disregard/move the topic.
    Create a Swirling Lines object (any setting will do), and then use the Break Apart command to get the individual lines.
    Select a line, and switch to Node Tool. You will see there are a lot of nodes in each line; in my case, 65 in the short lines and 129 in the longer lines.
    I tried Simplify Path, but I can't get that to retain the exact curvature.
    @Gremriel I will try to improve this, but for this effects it might need the nodes.
