Layers Panel Bugs: Delete with Drag to Trash Can Icon; Selected Object In Layers Panel not Selected on Artboard
  • Two Layers Panel bugs:
    1. From the Layers Panel, if you try to “delete” a selected object by the “drag and drop” into the Trash Can Icon method, the dragged object appears as a VERY LARGE shape of that object. Once over the Trash can, you have no real visual “indication” if you let go of the mouse button it will actually go in the Trash Can; although, usually it does indeed get deleted.
    1. If after you delete a selection by the “click and drag” into the trash can icon method in the Layers Panel, if you try to select an object as your NEXT action, in the Layers Panel specifically (not artboard), it will have a dot placed in the selection circle but it won’t be selected in the Artboard. ONLY after you try to select the object (or any other any object in the layers panel) a second time will it actually be selected on the Artboard.
    @Vector-Rock Added these to the backlog.
