'Bug
https://youtu.be/B2tTLZYp8ns?feature=shared
My operation: The letter is combined with the path, and a copy is mirrored and cloned. Press Enter once in the angle rotation function of the path panel for the original letter, and repeat the operation once for the copy to make the angle of the copy consistent with that of the original graphic. Perform Ctrl+D (My operation: The letter is combined with the path, and a copy is mirrored and cloned. Press Enter once in the angle rotation function of the path panel for the original letter, and repeat the operation once for the copy to make the angle of the copy consistent with that of the original graphic. Perform Ctrl+D (in-place duplication) on the original graphic, and click the copy with the Shape Picker tool. Since I often forget their linkage, I deleted the copy, resulting in the deletion of the graphic I needed. When I undid the operation, I found that the original graphic had shifted in position, requiring many undos to restore the original position.
@monsterfox I will try to replicate this.
