update 1.2.055
 VectorStyler 1.2.055 release notes- Fixed a bug in repeater expanding.
- Import hex colors from CSV files as palettes.
- Better compression ratio when saving images in JPEG mode in the document.
- Improved color palette insertion with drag and drop.
- Added a new page insertion action for the customizable actions list.
- Fixed a bug in vector brushes on text shapes.
- Show outline for objects with no style when dragging.
- Apply spot color tinting in color variations.
- Fixed a bug when adding colors into an empty palette.
- The trim tool should not cut empty width profiles.
- Fixed a bug in the appearance panel menu options.
- Added a new selection option to select objects inside or intersecting with the selected shapes.
- Fixed a bug in using object styles.
- Panels and views should not be opened on disconnected screens.
- Pencil tool default style should work with no stroke also.
- Fixed a color mode naming issue in the color settings.
- Fixed a crash when using HSL color wheels.
- Fixed a color picker button sensitivity issue in the color panel.
- Selecting a color style in the color panel should update the sliders and the wheel.
- Added actions for some basic alignment options to be available for customization.
- General stability improvements.
 @VectorStyler first time I've encountered this issue: first VS doesn't seem to launch and it takes several minutes to open (not tested). Should I uninstall VS first?
 @VectorStyler uninstalling and reinstalling doesn't help. I'm going back to the previous version.
 @B-Vs-V I will try to find out what causes this.
 @B-Vs-V Test are running here on Windows 11 and 10.
 I tried again the install on a Windows 11 machine and it seems to be working.One thing: uninstall, but also remove the user files from c:\Users<user name>\AppData\Roaming\NumericPath\VectorStyler1.2\vector\data\resources\ and then install
 @VectorStyler no user files there (e.g., no NP folder) after uninstalling.
 FYI - The new build update installed just fine on the M1 Mac here. So the issue @B-Vs-V is having seems to be windows related
 first VS doesn't seem to launch and it takes several minutes to open Another thing: does it launch at all, and what about the second attempt (the code signing certificate is changed, but it is from the same provider).
 @VectorStyler VS finally launches, but it takes some four minutes, and every time.
 VS finally launches, but it takes some four minutes, and every time. Don't know what can cause this. I will try to get feedback from other Windows based users.
 @VectorStyler Well, normal behaviour now but I had to make the NP file in C:\Users...\AppData\Local... inaccessible. I lost all my presets but I propose to reintegrate file by file from the old directory.
 @B-Vs-V said in update 1.2.055: I lost all my presets but I propose to reintegrate file by file from the old directory. The presets can be copied manually.
 Nice, thank you for this!
 My VS opens, but it also triggered my virus scanner (Avast) to run a check on it. What's odd is the program was open in the background while it was running its scan. Then it closed it and reopened it after it was finished (it passed). On close, this popped up though:  I had to add it as an exception.
 @debraspicher I will contact Avast about this. This happened once in the past when I changed the code signing certificate.
 @VectorStyler said in update 1.2.055: @B-Vs-V Test are running here on Windows 11 and 10.
 I tried again the install on a Windows 11 machine and it seems to be working.One thing: uninstall, but also remove the user files from c:\Users<user name>\AppData\Roaming\NumericPath\VectorStyler1.2\vector\data\resources\ and then install @VectorStyler No folder there (Roaming) after having installed VS .055 but NP is located there C:...\AppData\Local
 The update on windows 10 is just working fine for me.
 No problem here either (win 10), Vectorstyler started and ran
 as usual
 Thanks for the update! I too am on Win 10 and the update installed and ran without issues.
