Adding swatches to default main color panel has issues
  • There's another issue when adding spot colors from one palette directly into the main default color panel. As I drag a color into the default color panel, it automatically adds the color before I fully drag the swatch into the default color palette. If I go all the way across, it seems to add a non spot-color version of the color as well. in this video you can see my try ti with a purple swatch - it creates two - one marked as a spot color and one not.
    I then tested the "test" palette I reported before that I made from scratch (made with no colors inside it initially) and this time some of the colors display as black and then don't show properly there
    Both issues are visible in my screen video here
    @Boldline I opened a bug on this.
