VS crash: changing the colour (gradient) of an object after having transformed with clones
I've created an object and applied ‘envelope’ as a shape effect, then applied the Transform feature with clones. A change in colour gradient causes VS to crash (crash reports sent).
@B-Vs-V I opened a bug on this.
@B-Vs-V I got the crash logs, but could not replicate the crash.
Is there a sample file that can be used to replicate this? Thanks!
@VectorStyler Unfortunately, I continued to work on this design and - I don't know why - the link between the original object and the clones was lost in terms of colour. In other words, even if I change the colour of the strokes on the reference object, the clones remain unchanged... I can, however, affect a change in shape...
@B-Vs-V said in VS crash: changing the colour (gradient) of an object after having transforming with clones:
The links gets broken if any of the fill or stroke styles of the clones are changed.
@VectorStyler I managed to repeat the issue. I'm sending you the test file.
@B-Vs-V The crash can be replicated here also!
@VectorStyler Hope you get it fix soon VS crash if I change various properties of the original object.
