Graphic Tablet and Windows Ink
My thoughts after testing update 1.2.041 with widows ink disabled and "Use tablet driver" in Settings enabled:
- The stylus works, pressure works!
But:
- After a while of drawing there is a significant slowdown in VS
- Using Path Brush Tool in larger zooms causes a stroke to be jagged - Video
@Harry I will try to replicate these. How long it has to be used to slow down in drawing?
@VectorStyler As you can see in the recording above, every time I start to draw a new line, there is a slowdown after about 2-3 sec. The biggest problem is with curves, spirals, etc.
