    • Users
    • Groups
    • Admin
    beta 1.2.011
    5 Posts 0 Posters 6.2k Views 1 Watching
    • V Offline
      vectoradmin
      VectorStyler 1.2.011 release notes
      • Multiple blend improvements and bug fixes.
      • Show references also when searching for styles.
      • Selecting a file in Open Recent should activate document if already opened.
      • Copy - pasting objects from inside moved layers.
      • Improved reference style handling.
      • Copy - pasting objects containing references should handle the reference links correctly.
      • Fixed possible crash when using Performance sections of the Settings view.
      • Fixed a bug in the color and style picker tools.
      • Confirm yes/no alerts with the return key.
      • Correct arrow direction on outlines with retracted handles.
      • Snapping in Pen tool when holding the Space key.
      • External palette to highlight the color of the selected object.
      • Creating new character and paragraph styles should keep the base style link intact.
      • Proportional mode button in shape options view.
      • Scale the character leading with the text.
      • Improved PDF exporting of certain fonts.
      • Changing font family should keep the weight.
      • Improved blending of open shapes.
      • Converting a frame text to shape text should position the text correctly.
      • Highlight the last action in the Recent Actions panel.
      • Allow decimal point settings for pixel units also.
      • Separator in palette grid to be optional.
      • Use selected unit in New Document Setup view.
      • Tab key ordering in the the New Document Setup view.
      • Right click menu in New Document Setup template list to remove template if allowed.
      • Add folder tools to the Symbols panel menu.
      • Single inset mode in text frame options.
      • Dragging the scroll bar in the Layers panel should start from the current position.
      • Improved iconified panel handling.
      BoldlineB 1 Reply Last reply Reply Quote 8
      • V Offline
        vectoradmin
        There is a problem with some text resources in the new beta build. An update will be uploaded today.
          Boldline @vectoradmin
          @VectorStyler said in beta 1.2.011:
          Would someone be willing to elaborate on this feature? For me, the space bar key activates the hand/pan tool whether I press it before or after pressing and using the pen tool.
          V 1 Reply Last reply Reply Quote 0
          • V Offline
            vectoradmin @Boldline
            @Boldline said in beta 1.2.011:
            When moving a control point, holding the spacebar will move the node with the control point. The new thing here is that this node will also snap to guides.
            • V Offline
              vectoradmin
              I uploaded a fix with the text resources issue.
              Powered by NodeBB.
