update 1.2.006
    VectorStyler beta 1.2.006 release notes
    • General stability improvements.
    • Improved MacOS Sonoma compatibility.
    • Fixed a bug with the knife tool on complex shapes.
    • Fixed a bug in SVG and PDF text importing.
    • Fixed a regression in repeater.
    • Changing object size inside flipped group should use the correct pivot point.
    • Exclude in composite shape to be the same as the exclude operation.
    • Paste appearance to an object with existing object style.
    • Switching to gray-scale sliders should select a gray color.
    • Scaling text containing a local baseline path.
    • Improved paragraph style handling.
    • Show all available backup files when opening the app.
    • Allow scrolling of numbers in color fields.
    • Show the outline of a text frame when using the Node tool.
    • Added a preview option in shape view.
    • Path editing in outline mode to preview the moved path.
    • Expand symbols command to work inside groups also.
    • Improved symbol spray and adjustment tools.
    • Rasterize to use correct object size when distortion image effects are used.
    • Option to preview vector brush settings from modal view.
    • Better handling of images as masks inside vector brushes.
    • Improved brush tip preview in eraser and path brush tools.
    • Contour options to allow color mode selection.
    • Select tool tip delay option without restarting the app.
    • Better handing of snapping in shape drawing tools.
    • Allow monochrome icons when customizing icons.
    • Update color panel when color style of selected object changes.
    • Fixed a bug in text frame option selection.
    • Additional transform panel options for selecting stroke and effect transformation modes.
    • Use the guideline options selected in artboard format of document setup.
    • Better handling of blend objects inside tiling patterns.
    • Set the length of a side for a polygon shape.
    • Scatter brush to use the width profile for symbol scaling.
    • Transform angle selection from the horizontal transform panel.
    • Copy and paste objects between artboards should keep object position.
  • @VectorStyler said in update 1.2.006:
    Forgot the hovering?
    @Ayo said in update 1.2.006:
    Could be. It is shown when selected.
  • Not sure why I always have issues with upgrading VS on my Win11 machine.
    If I open the .005 beta, I get a notification that a new version is available. I click yes to download and install. The install finishes, but when I double click the icon, it opens up the .005 version, and shows me the new version message again.
    When I download the new version manually, and run that, I get a dialogue that gives me the choice of repair or remove. Choosing the repair option, the installer does something, but when I start the app again, it is still version .005 and the new version dialogue appears again.
    A new folder is created in /Program Files/NumericPath/VectorStyler 1.2, which only contains 34mb of files, but no executable.
    *edit
    A third icon appeared on my desktop. When I doubleclick that, a UAC window appears (I think it's called UAC), which asks me if I want the .msi file to apply changes. When I click yes, I get a dialogue that tells me the "The feature you are trying to use is on a network source that is unavailable". It is not, it's on my C drive. When I click OK, it tells me the installation package is invalid. When I click cancel, I get an unrecoverable error message.
    *edit 2
    The update from 114 to 115 works as expected.
    @Gremriel I did test the update on Windows for the beta. Not sure what could cause this.
  • @VectorStyler
    There was an entry for VS 1.2.006 in the Windows App Uninstaller. I uninstalled both betas, downloaded it again, and the beta works now.
