    Can't move combined selection
    24 Posts 4 Posters 41.6k Views 4 Watching
      Subpath @Ayo
      @Ayo said in Can't move combined selection:
      @b77
      Not complex, but attach the file anyway.
      0_1698330009516_Move2.vstyler
      tried it with your file
      everthing works as expected
      Here the Video
      • b77B Offline
        b77 @Ayo
        @Ayo Moving or duplicating the two black shapes in the file works here as it should.
        No idea what is causing this. Maybe you're using a stylus and not a mouse or trackpad?
        OK, you're on a Mac.
        You can try to move the two files (settings.xml and workspace.xml) somewhere else:
        • close VS
        • switch to the Finder
        • click the 'Go' menu > Go to Folder…
        • paste this: ~/Library/Application Support/NumericPath/VectorStyler1.2/vector/data/resources
        • press Enter/Return.
        • move these two files (settings.xml and workspace.xml) outside that folder.
        Then you can start the app again and see if the issue is solved.
        If it's solved, send the .xml files to the developer's email (csraba at this domain).
        AyoA 1 Reply Last reply Reply Quote 0
        • L Online
          Li Xiao @Ayo
          @Ayo Tested it and there are no issues. Try clicking on "Restore Defaults (Help\Restore Defaults)" and then test it again.
          • AyoA Offline
            Ayo @b77
            @b77 Using a mouse.
            Followed your procedure and problem is solved Indeed!
            Still annoying that that happens.
            Will send the .xml files to the developer's email.
