    Can't move combined selection
    24 Posts 4 Posters 41.6k Views 4 Watching
    • AyoA Offline
      Ayo @b77
      @b77 said in Can't move combined selection:
      Use RecordIt or some other screen recording app — it's much faster
      than having to take screenshots, combining them and writing explanatory
      text over them.
      Did my best, downloaded Recordit but my recordings gives grey empty screens.
      Again something to solve.
        b77 @Ayo
        @Ayo If on Windows: Subpath had only good things to say about ScreenToGif
        AyoA S 2 Replies Last reply Reply Quote 0
        • AyoA Offline
          Ayo @b77
          @b77 On Mac
          Didit!
          Had to toggle a switch in System Settings, Privacy & Security.
          Here my first recording😃 but doesn't solve the problem: https://recordit.co/BbYZq7vnvt
            Subpath @b77
            can only repeate my praise 🙂
            ScreenToGif ( Win only) is a very small screen recorder (only 170 kb)
            with features you won't believe, especially at this size
            I often use it for longer screen recordings
            because Recordit sometimes refuses to upload
            Then I play the recording with Screentogif and
            use Recordit to record that. Because Recordit stores
            the record online, which Screentogif doesn't do
              Subpath @Ayo
              @Ayo
              Here my attemp, work as expected
              Win 10, VS 1.2 Beta
              Here the Video
              • AyoA Offline
                Ayo @Subpath
                @Subpath @b77
                About your recordings: you both can do amazing things that I can't do.
                Glad my classic textbook explanation still works. Advantage over Screen Recording is the exercise in VS. Working with, text, arrows etc. (For example, I notice that during my explanation the text cursor in the text boxes does not always want to appear. But that is an other issue.)
                • AyoA Offline
                  Ayo @Ayo
                  Not complex, but attach the file anyway.
                  0_1698330009516_Move2.vstyler
                  S b77B L 3 Replies Last reply Reply Quote 1
                    Subpath @Ayo
                    @Ayo said in Can't move combined selection:
                    @Subpath @b77
                    No problem, explain it with whatever you feel comfortable with
                    When it comes to screen recording, sometimes it's just easier
                    to figure out what someone actually does
                    By the way, I only started screen recording when I started
                    posting questions about VectorStyler in this forum.
                    I never needed it before.
                      Subpath @Ayo
                      tried it with your file
                      everthing works as expected
                      Here the Video
                        b77 @Ayo
                        @Ayo Moving or duplicating the two black shapes in the file works here as it should.
                        No idea what is causing this. Maybe you're using a stylus and not a mouse or trackpad?
                        OK, you're on a Mac.
                        You can try to move the two files (settings.xml and workspace.xml) somewhere else:
                        • close VS
                        • switch to the Finder
                        • click the 'Go' menu > Go to Folder…
                        • paste this: ~/Library/Application Support/NumericPath/VectorStyler1.2/vector/data/resources
                        • press Enter/Return.
                        • move these two files (settings.xml and workspace.xml) outside that folder.
                        Then you can start the app again and see if the issue is solved.
                        If it's solved, send the .xml files to the developer's email (csraba at this domain).
                        • L Online
                          Li Xiao @Ayo
                          @Ayo Tested it and there are no issues. Try clicking on "Restore Defaults (Help\Restore Defaults)" and then test it again.
                          • AyoA Offline
                            Ayo @b77
                            @b77 Using a mouse.
                            Followed your procedure and problem is solved Indeed!
                            Still annoying that that happens.
                            Will send the .xml files to the developer's email.
