    A node selection issue that slows node editing
    6 Posts 4 Posters 5.7k Views 4 Watching
    • b77B Offline
      b77
      I frequently bump into this click-and-drag (box select) issue where
      after I select a single object in order to edit only its nodes, the first
      click of click-and-drag can still select and bend the segment of an
      unselected shape by mistake:
      alt text
      As you can see, I'm bending the segment of the other shape if I'm
      not careful to start the click-and-drag exactly in the empty space
      between them.
      Can somehow any interaction with an unselected shape be disabled
      when clicking-and-dragging once a shape has been selected and
      you're in node editing mode?
      Is there some drawback to this more restricted approach?
      S encartE VectorStylerV 3 Replies Last reply Reply Quote 1
        Subpath @b77
        @b77
        something like this also happens to me from time to time
        and when you drag from the inside ?
        or use the lasso selection in these cases?
        came to my mind.
        the pointer seems to me here in certain areas
        a bit too sensitive, maybe it could help if we
        could regulate the sensitive range size ?
        short video here
        • encartE Offline
          encart @b77
          @b77 said in A node selection issue that slows node editing:
          I would also like to know this.
          I am experiencing this problem when using lasso tool. I have already learned that the first click has to be away from the objects, otherwise I make an accidental edit. I definitely join the request to isolate selection. It can be as an option.
          • b77B Offline
            b77 @Subpath
            @Subpath I agree that there is also the opposite direction alternative for box select (from
            lower right to upper left in this case) but it's not the default way to box select β€” you need to
            pause for a second, "inspect the area" then decide to click-and-drag like that. All this adds
            up and it slows you.
            @encart Thanks, you're right, it also happens with the Lasso tool. πŸ‘
            Just to make sure there's no misunderstanding:
            It's good that the app lets you select nodes from all shapes when nothing is selected,
            so I wouldn't change that. That's fast.
            It's just that once a shape is selected, it's not in complete isolation mode for node
            selection β€” while nodes from the unselected shapes are not included when you
            click-and-drag over them (which is great), a misplaced click on a segment of
            another shape will interact with it and bend it.
              VectorStyler @b77
              @b77 Added this to the backlog. Not sure yet of what is the solution here.
              The problem is that click+drag should be able to move nodes / segments.
              • b77B Offline
                b77 @VectorStyler
                @VectorStyler said in A node selection issue that slows node editing:
                OK, but by 'click-and-drag' i meant 'box select'.
                That should not select and bend any segment of any other shape than the selected one.
                If it's doable… πŸ™‚
