A node selection issue that slows node editing
I frequently bump into this click-and-drag (box select) issue where
after I select a single object in order to edit only its nodes, the first
click of click-and-drag can still select and bend the segment of an
unselected shape by mistake:
As you can see, I'm bending the segment of the other shape if I'm
not careful to start the click-and-drag exactly in the empty space
between them.Can somehow any interaction with an unselected shape be disabled
when clicking-and-dragging once a shape has been selected and
you're in node editing mode?Is there some drawback to this more restricted approach?
something like this also happens to me from time to time
and when you drag from the inside ?
or use the lasso selection in these cases?
came to my mind.the pointer seems to me here in certain areas
a bit too sensitive, maybe it could help if we
could regulate the sensitive range size ?
@b77 said in A node selection issue that slows node editing:
you're in node editing mode?I would also like to know this.
I am experiencing this problem when using lasso tool. I have already learned that the first click has to be away from the objects, otherwise I make an accidental edit. I definitely join the request to isolate selection. It can be as an option.
@Subpath I agree that there is also the opposite direction alternative for box select (from
lower right to upper left in this case) but it's not the default way to box select β you need to
pause for a second, "inspect the area" then decide to click-and-drag like that. All this adds
up and it slows you.@encart Thanks, you're right, it also happens with the Lasso tool.
Just to make sure there's no misunderstanding:
It's good that the app lets you select nodes from all shapes when nothing is selected,
so I wouldn't change that. That's fast.It's just that once a shape is selected, it's not in complete isolation mode for node
selection β while nodes from the unselected shapes are not included when you
click-and-drag over them (which is great), a misplaced click on a segment of
another shape will interact with it and bend it.
@b77 Added this to the backlog. Not sure yet of what is the solution here.
The problem is that click+drag should be able to move nodes / segments.
@VectorStyler said in A node selection issue that slows node editing:
OK, but by 'click-and-drag' i meant 'box select'.
That should not select and bend any segment of any other shape than the selected one.If it's doableβ¦
