Image Effects
@VectorStyler What I am doing to do in create button pressed and normal state like the image below:
But when I apply outer shadow and increase blur it bleed to all direction.
I found the there is no offset of control of shadow like this.
@Jayanta-Das I'm not sure that it applies to this case, but in Drop Shadow there is the Size field that controls the offset.
@Jayanta-Das As for the other images, I think these look more like using Emboss.
@VectorStyler Emboss effect applied within the shape. I am trying to get neumorphic style button where shadow and lights are applied to outside of the shape
Edit: When the button is in pressed state effects are applied inside the shape and in normal state effects are applied outside of the shape.
@VectorStyler If you could add offset control in shadow and glow it would be a great addition.
@Jayanta-Das said in Image Effects:
I think, technically this is not difficult, but how a glow with offset would look like?
@VectorStyler Sorry I mean Offset to shadow and angle to control the direction of glow.
