Image effects issues
 More observations- When adding an image effect from the layers panel bottom icons no additional effects can be added
- When using the icon next to the object in the layers panel, I can
- When adding image effects, every second effect does not immidiately offer settings because it is not selected automatically
 @Ingolf This is clearly a bug. A similar issue with accessing the options of Levels has been reported.
 Can be replicated here also.
 I will try to fix this ASAP.
 @Ingolf These issues should be fixed in build 1.1.062
 Looks that way, thanks!
