Keyboard movement and brush size bugs
 There are bugs I've noticed with a few buttons and values. I've made 4 screen recordings to see them:
 @VectorDave Hi, and welcome to VectorStyler. In order of videos: 1). I managed to replicate the issue when decreasing the size, when increasing the context panel updates. I added this to the backlog. 2). The popup slider works differently, the button is only to open the slider (it did confuse others also, so I have to find a better icon for that): https://recordit.co/V9lwPvOA7c 3). This must be a regression in the number editor(s). The lower limit for this is 0.1, but for some reason it shows 0. Will be fixed ASAP. 4). Yes, this is because the lower limit is set to 0.1 pt (typographic pt) and at the current resolution this is larger than 0.1 pixels. The only fix I can do here is to have a smaller lower limit (maybe 0.01 pt?).
 @VectorStyler Hello. Thanks. Sorry for the late replies, but it was a very busy week. -
That's great. Thanks.
I understand now.
Thanks.
That would be helpful.
 @VectorDave This issue should be fixed in build 1.1.062
 It's fixed. Thanks.
