Repeater halftone problem on rasters
@Dazmondo This (the dollar scan) is much more complex and because it was done manually, even specialized software like StrokesMaker (very expensive and PC only) can not imitate the slight variations perfectly.
https://www.guard-soft.com/strokes_maker.html (click the 'Gallery' button).
I think an alternative would be dividing the image into sections (forehead, eyes, brows, cheeks, etc), bending and blending lines in different directions for each section then feeding the rasterized versions of each blend object to the Repeater.
I haven't tried it and don't plan to — it's a lot of work, but it might do it.
Hmm… there's a StrokesMaker app sold by a Russian guy for 99 USD — not sure if this is related to the one from GuardSoft…
https://www.strokesmaker.com/ (Mac and PC version available)
@b77 said in Repeater halftone problem on rasters:
I had a try, well started and gave up trying, a splitting a face into sections technique when I first got Vectoraster 3 in 2009 - At the moment I think the repeater would be unable to produce anything close to VR, but who knows, with VS ability to distort and bend vector strokes it may be doable in the future if we get a way to use simple lines in Repeater?
https://www.strokesmaker.com/ (Mac and PC version available)Strokesmaker looks like it's probably the closest I've seen to achieving this type of thing but I suspect the really authentic looking art on the site would need a lot of work ---- ACE
@Subpath said in Repeater halftone problem on rasters:
@b77
Here a Video Tutorial about how they create those Lines
in this Software.
Youtube VideoWow just watched the video - giving me ideas how to do this in VS --- thanks
Is there a way to get multiple color results from an imported raster image?
@Boldline Export separations with Print to File and open the generated PDFs back in VS, change the black shapes to the correct color for the first three files (C, M, Y) or for the Pantones, and run Repeater on them.
@b77 Thanks!!!! I am going to try that and get back to you. This is exciting!
@VectorStyler Can a pseudo-separation be done using the color adjustment effects, so that each of four duplicates of a color image can have the cyan, the magenta, the yellow and the black separation, and Boldline doesn't need to export separation PDFs for this?
I tried a bit with the available effects but couldn't do it. Maybe I didn't try enough?
@b77 Maybe with the Curves color effect. Create four copies of an image and clump down all but one color channel curve on each.
@Boldline said in Repeater halftone problem on rasters:
Just had a quick mess around by separating in Affinity, importing into VS and assigning repeater dots --- works great - obviously needs tweaking but opens up a few doors for creating duotones for T-shirts
@VectorStyler Nope, tried that. It applies cyan, magenta and yellow where's only black or grey.
Probably because the effect is RGB based (the image was changed to CMYK color mode).OK, I'll post a solution here if I find an effect that does this.
@Dazmondo said in Repeater halftone problem on rasters:
Heres the VS doc: https://drive.google.com/file/d/1IefoB6blZgPRVzZ6A_7UVgZww0CERITJ/view?usp=sharing
i though it would give us a few ideas
and maybe VectorStyler too
etched style halftones
There is a larger repeater task planned just after 1.2, so not very soon but soon.
@b77 Ok I'm finally trying this but I'm a complete newbie when it comes to most printing setups. I have it set to "print to file" and "separate", but am I supposed to be running it with all 4 CMYK?
Are there other settings I should be adjusting? Thanks for your help!
@Boldline That's it — hit OK and you should get one PDFs for each process color (C, M, Y, K).
@b77 ok - for this end result I really only want two colors, gray and white. It's going to go on a black shirt. Right now I have four pdfs that all look almost identical
@Boldline Then the white should be a spot color (a Pantone maybe) and make sure the grey object is made only of blacK ink — no mixing of cyan, magenta and yellow.
