Double path in outline mode
Double path in outline mode - bug or feature?
Edit: When there is an image effect added, it happens.
@Ingolf Doesn't happen here — I tried both with 'Show Segment in Pen Tool' enabled and disabled.
@Ingolf Ah… saw the other thread just now and if the image has an effect indeed you get a double-path when in Outline Mode.
@b77 said in Double path in outline mode:
Yep, and still happens after the image effect is deleted. (Saving and reopening document in fresh VS restores normal functionality if the image effect was removed)
@Ingolf This problem should be fixed in build 1.1.048
