I would like to make a brush... a simple brush
@PatrickM said in I would like to make a brush... a simple brush:
In this image, the circles are bent a little bit. If the issue is the size (width) of the brush, than that can be fixed by either creating a smaller group first, or by setting the Scaling in the Pattern Brush view to a smaller value.
@vectoradmin said in I would like to make a brush... a simple brush:
yes, sure, it is not perfect but there is not so much objects' distortion. To be honnest, I don't remember how I did this in AI & the kind of brush I'd chosen.
Sure I will continue to dig in VS... I won't give up but I need more time to test all these brushes setup, time I don't have much right now
PS : I've tried to open an old AI file (not related to this issue) and VS crashed. I suppose VS send you the crash report.
@PatrickM Got the crash report. I will try to fix based on that, if you can send me the file by email to csraba at vectorstyler.com it would help replicating the issue (file will be removed, once the bug is fixed).
thanks but it doesn't work like I would like:
What would be a good way to have in this case?
@vectoradmin Would it be possible to add this option to repeat the pattern for this type of brushes?
The pattern is repeated along the path. If I understand correctly the problem is that the shapes get stretched.
On the other hand, if we do not stretch the shapes (rigid shapes), then they get overlapped.If we would keep the whole pattern content rigid (not possible at this time), then the overlapping would get worse.
I think the best option is that I will try to figure out the difference between what VS does and what is in the example form that AI file. For that it would be great if you could send me the AI file, and would also help in finding the reason for the crash
@vectoradmin I did test the same simple drawing in VS and AD.
Although not vector, the brush is fine in AD in a sense I get what I wish:
This is wrong in VS:
and I don't know how to get itI don't have time to go further but every one can try this.
P.
@PatrickM Attached the file with the vector pattern brush example: 0_1648459966486_patternbrush3.vstyler
@vectoradmin Great and perfect and all vectors !!
Could you do a quick (but detailed) video to see where I miss the point doing this ?
Thanks in advance.
P.
@PatrickM https://recordit.co/uPU6wgT2Q8
@vectoradmin Thank you very much for your help and presence on this forum
