    28 Posts 5 Posters 33.6k Views 5 Watching
      VectorStyler @B-Vs-V
      @PatrickM You can open old AI files in VS 🙂
      EDIT: or new ones also.
      • B Offline
        B-Vs-V @VectorStyler
        Well, fine but if I find the file on one of my external hard disk, what usefull information can I get since VS deal with brushes in a diffrent way ? Anyway, I'll check when I can.
          In this image, the circles are bent a little bit. If the issue is the size (width) of the brush, than that can be fixed by either creating a smaller group first, or by setting the Scaling in the Pattern Brush view to a smaller value.
          • B Offline
            yes, sure, it is not perfect but there is not so much objects' distortion. To be honnest, I don't remember how I did this in AI & the kind of brush I'd chosen.
            Sure I will continue to dig in VS... I won't give up but I need more time to test all these brushes setup, time I don't have much right now 😓 .
            PS : I've tried to open an old AI file (not related to this issue) and VS crashed. I suppose VS send you the crash report.
              @PatrickM Got the crash report. I will try to fix based on that, if you can send me the file by email to csraba at vectorstyler.com it would help replicating the issue (file will be removed, once the bug is fixed).
              • B Offline
                  On the other hand, if we do not stretch the shapes (rigid shapes), then they get overlapped.
                  If we would keep the whole pattern content rigid (not possible at this time), then the overlapping would get worse.
                  I think the best option is that I will try to figure out the difference between what VS does and what is in the example form that AI file. For that it would be great if you could send me the AI file, and would also help in finding the reason for the crash 🙂
                  • B Offline
                    This is wrong in VS:
                    and I don't know how to get it
                    I don't have time to go further but every one can try this.
                    P.
                      • B Offline
                        B-Vs-V
                        Thanks in advance.
                        P.
                          • B Offline
                            @vectoradmin Thank you very much for your help and presence on this forum 👍
                              FanVidder @VectorStyler
                                Boldline @FanVidder
                                @FanVidder What task(s) are you trying to complete?
                                  FanVidder @Boldline
                                  @Boldline actually, I've just found a site containing enough tutorials to get me started. I find the workspace really daunting (I use Illustrator at college and I also have Affinity, but I can't afford Adobe at home). How do I set up my workspace so that all the panels are available? Thanks.
                                  I managed to find the Tutorials page on here.
                                    Subpath @FanVidder
                                    @FanVidder
                                    I don't find the basic steps all that complicated. CorelDraw was my main
                                    application before VS, i know a few other vector graphic apps too. It took
                                    me a while to get used to the new terminology.
                                    It might look complicated, and some functions are harder to understand.
                                    Just take your time and go step by step.
                                    Yes, there aren't many tutorials on YouTube, probably due to the still small
                                    user base. I do post tutorials here in the forum from time to time, but I have
                                    no interest in dealing with YouTube; it's just too much effort.
                                    The best thing to do is search the forum, check out the tutorial section, or simply ask.
