Repeat last action (any simpler way?)
 In affinity designer last action can be done by control + J like in this video https://recordit.co/JMF2O0xKkB
 I know in tranform I can do that. Is there any simpler way to do that.
 @Jayanta-Das Shift+Control+R on Windows, Control+R on Mac. In VS multiple recent actions are available (there is also a Recent Actions panel). Accessing the last of these is only available as a shortcut,the menu will contain all.
 @vectoradmin What I got is https://recordit.co/6ymWsqU9nv.
 @Jayanta-Das Looks like the pivot point is not correct after the rotation. I think this might be a bug.
 @Jayanta-Das As a workaround until this pivot issue is fixed, I would duplicate the first object on the opposite side of the circle, then select both and duplicate them around the circle.
 @b77 Ya, I discover another way to do this. First copy the object, rotate the the copied object, then Control + D do the same.
 In VS multiple recent actions are available (there is also a Recent Actions panel). Accessing the last of these is only available as a shortcut,the menu will contain all. @vectoradmin could you please tell me where I can find this "Recent Actions" panel ?
 Thanks.
 @PatrickM Panels -> Presets -> Recent Actions
 @vectoradmin said in Repeat last action (any simpler way?): @PatrickM Panels -> Presets -> Recent Actions Thanks. I didn't look there
