Contex Menu bar icons
As in the screenshot icons of Section 1 and 3 are similar in size while icons in section 2 are smaller as compare to 1 and 3. And in my 14" PC I sometime mistaken the the icons, then I undo and try other.
But in Other software like Affinity Designer Boolean icons can be differentiate very easily.
I am not comparing this two, of course VS is more advance and it has more boolean functions than AD.
@Jayanta-Das Icons in Section 2 should not be smaller. This seems to be a bug.
Try resetting the workspace (View -> Workspace -> Restore Default).If this issue persists, let me know.
The other problem is differentiation, I think here the solution would be to customize the toolbar to user preferences (View -> Customize -> Customize Toolboxes, and then select Context Panel in the Toolbox field).
@vectoradmin After restoring to default the icons are still smaller.
The buttons are identical in size, but I guess what Jayanta says is that the drawings on the Combine buttons look slightly smaller than the other buttons. Is that correct, @Jayanta-Das ?
@b77 The height of the buttons and the icons also are smaller than the rest
@vectoradmin What about available free space? Is it possible that when there is not enough space the elements are scaled down?
@Jayanta-Das It would help if you write the Windows or Mac version you have, and also if you can send the screenshot to the developer, or post a link to an uncompressed version of it. The forum converts big images to JPEG, so your screenshot got the jaggies and it's difficult to see the issue.
EDIT: Never mind about the jaggies… I should have clicked the image to see it uncompressed.
@vectoradmin I have seen other's context menu screenshot they are fine. In my case because of the size of the icons it is difficult for me to differentiate.
I have seen this issue a few times and have it now. I don't remember how I fixed it once, but it is back. I did some customization of the toolbar I think triggered it, but I haven't had the time to investigate further.
Haha, no, it disappeared again!
@b77 I can see in the screen form @Jayanta-Das that the icons are clearly smaller, the symbol and the background.
@encart Oh… you're right… I didn't click the image to see it in the original size.
@b77 Sure I will. Can you please guide me where to send
@Jayanta-Das No need to send… the forum indeed compresses the image in the thread as JPEG, but if you click it you get the uncompressed original.
But it wouldn't hurt to go into your account settings and add your computer's OS and configuration to your signature.
@Jayanta-Das said in Contex Menu bar icons:
Clearly the buttons are smaller. I open a bug on this one, since they should be (and are here) of the same size as the others.
@vectoradmin I remove the group in Customize context menu and the re-add group and add actions now the button size comes to normal. One thing though I could not find exclude last action which was there before removing.
Fixed in build 1.1.016.
