Referenced duplicate+source and clone source not exported to SVG
If I export this file to SVG, only the clone is exported of the four objects.
@Ingolf I tried exporting and tested the result in Illustrator, Affinity and Firefox and it worked.
In what app did the exported file not show?When VS exports references, it will use the SVG "<use xlink:href ... />" links, these may be a problem in some apps.
@vectoradmin said in Referenced duplicate+source and clone source not exported to SVG:
When VS exports references, it will use the SVG "<use xlink:href ... />" links, these may be a problem in some apps.Exported from the mac version and problem seen in Affinity. Didn't check other programs.
Not seeing it either on Windows today. I will re-check when I am on macOS again later.
Did you try in... Vectorstyler?
It does open correctly in those programs you tried in, and does for me too, but now I remember that I actually opened the SVG in Vectorstyler itself.
@Ingolf I tried VS also and it worked. Send me the SVG file by email, I will try to replicate with that.
Done
I see the same behavior in VS on Windows and macOS, for the record.
@Ingolf Exporting reference objects (with Named Groups option enabled) should work now.
