@PatrickM In the Pattern Brush editor view (click the button next to the drop down), press the Options button.
This will open the effect options view.
Enable "Rigid Shapes" and confirm the brush options.
@PatrickM Here is the example with rigid shapes: https://recordit.co/7JWPDgv7tI
@vectoradmin thanks but it doesn't work like I would like and one can see it in your video: objects become separated :
@PatrickM Of course the objects become separated, the transformation along the path positions these shapes.
@vectoradmin like in AD or AI, a repetition of the same motif
exemples :
@PatrickM Align objects along a path is the closest I can think of in VS, but it is not linking the objects dynamically to the path.
In the example below, how is it possible to turn the corner downwards without stretching the circles a bit?
I did this in AI years ago and it worked perfectly but I don't have a licence anymore and -problem of a subscription- I can't check my file... if I still have it.
It's more problematic in AD and I can't do such curves either.
@PatrickM You can open old AI files in VS
EDIT: or new ones also.
Well, fine but if I find the file on one of my external hard disk, what usefull information can I get since VS deal with brushes in a diffrent way ? Anyway, I'll check when I can.
In this image, the circles are bent a little bit. If the issue is the size (width) of the brush, than that can be fixed by either creating a smaller group first, or by setting the Scaling in the Pattern Brush view to a smaller value.
yes, sure, it is not perfect but there is not so much objects' distortion. To be honnest, I don't remember how I did this in AI & the kind of brush I'd chosen.
Sure I will continue to dig in VS... I won't give up but I need more time to test all these brushes setup, time I don't have much right now
.PS : I've tried to open an old AI file (not related to this issue) and VS crashed. I suppose VS send you the crash report.
@PatrickM Got the crash report. I will try to fix based on that, if you can send me the file by email to csraba at vectorstyler.com it would help replicating the issue (file will be removed, once the bug is fixed).
On the other hand, if we do not stretch the shapes (rigid shapes), then they get overlapped.If we would keep the whole pattern content rigid (not possible at this time), then the overlapping would get worse.
I think the best option is that I will try to figure out the difference between what VS does and what is in the example form that AI file. For that it would be great if you could send me the AI file, and would also help in finding the reason for the crash
This is wrong in VS:
and I don't know how to get itI don't have time to go further but every one can try this.
P.
Thanks in advance.
P.
@vectoradmin Thank you very much for your help and presence on this forum
