    50 Posts 4 Posters 134.2k Views 3 Watching
      @b77 This is really awesome! Yes this is a CTF (Computer-to-Film) workflow. I did not know the technical names and I wanted to be sure I explained specifically how I export vector designs and for what purpose and on why they need to be opaque, etc...
      I downloaded your file and edited my settings and it produced the three pdfs as you mentioned - this is a lot like what I would do in Illustrator when I printed films while working at a screen print shop (instead of just doing the art in my office working for myself now) so I'm understanding completely what is happening - thank you for showing me. I will be doing this way going forward in VS.
      What I need to figure out still is a working registration black I can use when I do this method of printing... because I will want the registration black to be used for the registration marks on my designs and print on every output no matter what colors are chosen. I will add the name of the color for the film in that same Pantone colors so they print with each color
      @b77 said in Exporting Final Art from VS for others including non-VS users:
      where a RIP (usually software)…
      rasterizes the artwork as spot (full opacity) or halftones, then…
      Is it wishful thinking to get @vectoradmin to add a RIP to VS? πŸ™‚
      b77B VectorStylerV 2 Replies Last reply Reply Quote 2
        @Boldline Is that a regular printer, or one that is specially made to print on film? I guess it has its own driver. If it does, that should do the job. You can try with a gradient that goes from full opacity to full transparency.
          @b77 Standard printers are used - I think there are some that print on film easier than others do. From my experience there's no way to get it to convert something with a lowered opacity to halftones.... many people use RIPs for that... if there was a way for @vectoradmin to add even a simple RIP to VS, I think that would be amazing.
          A long time ago before I worked for myself, one of the Screenprinting shops was just beginning to experiment with halftone printing and we started with an open source RIP called "GhostRip"
          It was a little clunky 10 or so years ago when I used it. It took a number of steps at the time to use and eventually we went to using Accurip.
          Accurip however, has become the bane of many a screen printer due to its excessive cost and licensing.
            One thing to do is to gather (difficult) examples where merge or union is failing, or it is slow. There is no excuse of having VS merge be less usable than AI merge.
            Awesome! I appreciate that vision! Merge and Union improved a lot in 2021.
            I'll keep testing things and sending in examples when it happens. I know there were a few examples recently I sent in that you found worked better with union than with merge or vice versa. Are you able to go back and look at those?
              @Boldline said in Exporting Final Art from VS for others including non-VS users:
              Did you try using the Registration color in the VS default palette (should be just after the null color)?
              That should print on all plates.
                Regarding your screen printing photos above.
                Found it interesting that your designs are screen printed πŸ™‚
                I was a screen printer for about 12 years mainly printing foils
                and signs.
                And after that job I was a screen printer again for about 8 weeks in
                T-shirt printing and we had the same workflow as you describe with
                your photos above. Brings back some memories πŸ™‚
                After that I went into digital printing, and created the vector graphics there.
                  Boldline @Subpath
                  @Subpath That's really awesome! Would love to see some of your work, do you have a link? I kind of fell into screen print designing in 2010 and loved it immediately and have done it since. After working for a couple companies I decided to quit and start my own business in 2014 and have done it full time since. I don't do the actual printing myself, I just create the designs and sell them to printers who use them for their clients.
                  What kind of digital printing do you do now?
                    Subpath @Boldline
                    @Boldline, unfortunately can not show anything.
                    Screen printing was a long time ago. And for vector designs,
                    the company owns the rights.
                    In my last job, I was also only doing vector designs, new products
                    with marketing, the Designs were mostly safety signs and labels,
                    custom road signs and so on and Designs on customer request.
                    The digital printers were two "Gerber Edge," if you know them and we
                    also had two vinyl plotters, I forget the name. Later also a large
                    UV ink printer.
                    Btw. like your Designs and must say that you do a really good job.
                      Boldline @Subpath
                      @Subpath said in Exporting Final Art from VS for others including non-VS users:
                      thank you!
                      Would love to see stuff you do currently, even for yourself
                      S 2 Replies Last reply Reply Quote 1
                        Subpath @Boldline
                        Will look, but do not expect anything special
                        I'm more experimenting at the moment.
                        To find out solutions for some ideas.
                          I tried using the built in registration black to no avail.... it would not show up on the final output pdf.
                          I've attached the file here in hopes @b77 and @vectoradmin in particular could help me find a solution.
                          0_1641349834100_CC Bulldogs Seps.vstyler
                            Found the issue: it does not show up on the spot plates. This is a bug.
                              Subpath @Boldline
                              " ... What kind of digital printing do you do now? ..."
                              I don't work anymore πŸ™‚
                              I do vector graphics only for fun/hobby or friends now.
                              Here a small collection. The first two, are things I have
                              also done professionally. Whereas I designed "wood saws"
                              privately for a friend. The other, in my spare time to try
                              different styles.
                              The rest is private stuff. Lately I like to experiment with
                              symmetrical designs. I will continue to do so.
                              Btw. if you think the little man in the last line, would not be vector graphics πŸ™‚
                              Then you are half wrong. Is made in Concepts an app I like to use on my iPad.
                              It is a vector app but partially with bitmap like brushes. The others are mostly
                              CorelDraw.
                                Awesome! Getting this fixed will be great as I can begin to send out separation files exporting right from VS!
                                  Boldline @Subpath
                                  @Subpath Thanks for sharing your work! I really love that butterfly and horse in particular. I could see those making really awesome shirts for example. I would have guessed a raster image on that little man, lo. cool stuff. I love the symmetrical design studies - keep experimenting and sharing. If you figure out cool tricks in VS, let me know- share in the forum for sure. πŸ™‚
                                    Subpath @Boldline
                                    thanks
                                    ... If you figure out cool tricks in VS, let me know- share in the
                                    forum for sure ...
                                    I will definitely do
                                      Here yet two Videos that shows some Brushes
                                      of the "Concepts" App (iPad) and belive it or not.
                                      It is still vector graphics everything stay editable.
                                      Concepts, draw a shoe
                                      Concepts, draw a perfume bottle
                                        Boldline @Subpath
                                        @Subpath Are those brushes bitmap based though? I know that is an issue in the Affinity forum for example, 95% of their "vector" brushes are actually bitmap brushes that can look like vector but cannot be expanded or treated like pure 100% vector
                                          Subpath @Boldline
                                          "...Are those brushes bitmap based though? ..."
                                          These brushes are not skeleton brushes like in Affinity Designer, where you move
                                          a bitmap virtually on a vector line.
                                          In Concepts with the built-in watercolor, airbrush and pencil brush. I can zoom to
                                          the maximum (1600%) without it getting pixelated. And also with other built-in brushes.
                                          The watercolor brush even mixes the colors a little bit and everything runs smoothly,
                                          without any delays. In addition, Concepts has also an infinite canvas.
                                          Concepts behaves similarly to a vector application, but uses a different philosophy.
                                          Vector lines do not have Nodes, you can move a line into a curve with a Pull-Tool.
                                          There are also no Boolean operators to cut objects. You can fake it a bit with the masking tool,
                                          and there is a real vector eraser.
                                          I think it comes pretty close to a vector paint program.
                                            Boldline @Subpath
                                            @Subpath Awesome! I'll have to play around with it. I think I found the website
                                            https://concepts.app/en/
