Mirroring / Flip does not work as expected
Hi
Don't know if this is really a bug.
But Mirror/Flip does not work as expected in VS.If i mirror/flip an Artistic Stroke in VS
the shape is not mirrored.
Only the direction of the stroke.I sketch a line with an Artistic Stroke
then copied as reference
and mirror/flip one of the strokes
and the result is like on the picture.But I would like the shape is also mirrored.
@Subpath2 Added to the backlog. This is caused by the shape being transformed, while the brush is not transformed, just applied on the new shape.
@vectoradmin said in Mirroring / Flip does not work as expected:
@Subpath2 .... This is caused by the shape being transformed, while the brush is not transformed, just applied on the new shape.
That was also what I had suspected.
Thank you for taking note.
@Subpath This issue is actually a feature (applying the brush on the transformed shape).
But there was a missing feature related to this.
In Appearance panel, when the Brush style is selected on a brush object, the panel menu will have a Transform Content item enabled.
This can be used now to apply the brush on the transformed shape (unchecked), or first apply the brush on the non-transformed shape and then transform the whole brush (checked).
This should work in build 1.0.055
If i understand you right. You wrote that this was originally
intended as a feature, but I don't really see the benefit of it.Found it. But it does not work properly.
Here are my steps:
- I made a short artistic brush stroke
- and made copy of it as a reference.
- and flip the reference copy horizontally
But every time I edit this reference copy
e.g. with the Shape Editor Tool or when I move the
the original brush, the reference brush goes
goes back to its original state.As it looks by now, it doesn't work properly with reference
and clone yet.
@Subpath I will try to replicate this issue. An example file could help.
I have an example file, but how could i send you this ?
@Subpath send it to csraba at vectorstyler.com
@vectoradmin #
The file has been sent
Hi
Just like to say, that with the latest Update 1.0.057
everthing works fine now.
