    update 1.3.026
    6 Posts 4 Posters 39 Views 3 Watching
      VectorStyler 1.3.026 release notes
      • Option to show glyphs in Glyph panel by character code
      • Flipping rotated objects should not flatten the transform
      • Only allow loading of compatible profiles for color modes
      • Close filled paths in the Exclude operation
      • Fixed a bug in editing duplicated drop shadow effects
      • Fixed a regression in the merge operation
      • Fixed a bug in block shadow effect
      • Fixed a bug in intersecting shape with an object containing an image
      • Fixed a bug in the Curves effect when used in 32-bit display mode
      • Fixed a bug in how the displacement effect used objects containing image effects
      • Fixed a bug in handling the recent files list when the workspace is swapped
      • Fixed a bug in removing fill or stroke styles from group objects
      • Fixed a bug in refreshing screen while editing in GPU mode
      • Fixed a refresh issue when drawing with direct preview mode
      • Fixed a bug in converting text to curves of certain fonts
      • Fixed an error in editing text with translated UI
      M BoldlineB 861475_VctSt8 3 Replies Last reply Reply Quote 6
        monsterfox @VectorStyler
        @VectorStyler Has the issue where rectangles get styled after rotating 90 degrees not been fixed yet?
          VectorStyler @monsterfox
          @monsterfox said in update 1.3.026:
          Not yet.
            @VectorStyler Thank you for fixing these issues and continuing to improve VS reliability with boolean operations, effects, text handling, color management, and GPU editing. These were all good ones to knock out!
            • 861475_VctSt8 Offline
              861475_VctSt @VectorStyler
              After launching VS, a notification for the version 1.3.027 update appears. However, no matter how many times I try, it remains at version 1.3.026. Even after downloading the file from the web and replacing the existing one, it still shows as version 1.3.026.
              Checking the details of the downloaded file also shows it as version 1.3.026.
              Could the download link for version 1.3.027 be broken?
              LIc. 0 OS10.15.8
              LIc. 1 OS15.7.4
                VectorStyler @861475_VctSt
                @861475_VctSt Will be fixed
