    update 1.3.026
    20 Posts 5 Posters 196 Views 4 Watching
      VectorStyler 1.3.026 release notes
      • Option to show glyphs in Glyph panel by character code
      • Flipping rotated objects should not flatten the transform
      • Only allow loading of compatible profiles for color modes
      • Close filled paths in the Exclude operation
      • Fixed a bug in editing duplicated drop shadow effects
      • Fixed a regression in the merge operation
      • Fixed a bug in block shadow effect
      • Fixed a bug in intersecting shape with an object containing an image
      • Fixed a bug in the Curves effect when used in 32-bit display mode
      • Fixed a bug in how the displacement effect used objects containing image effects
      • Fixed a bug in handling the recent files list when the workspace is swapped
      • Fixed a bug in removing fill or stroke styles from group objects
      • Fixed a bug in refreshing screen while editing in GPU mode
      • Fixed a refresh issue when drawing with direct preview mode
      • Fixed a bug in converting text to curves of certain fonts
      • Fixed an error in editing text with translated UI
      M BoldlineB 861475_VctSt8 L 4 Replies Last reply Reply Quote 10
        monsterfox @VectorStyler
        @VectorStyler Has the issue where rectangles get styled after rotating 90 degrees not been fixed yet?
          VectorStyler @monsterfox
          @monsterfox said in update 1.3.026:
          Not yet.
            @VectorStyler Thank you for fixing these issues and continuing to improve VS reliability with boolean operations, effects, text handling, color management, and GPU editing. These were all good ones to knock out!
            • 861475_VctSt8 Offline
              861475_VctSt @VectorStyler
              After launching VS, a notification for the version 1.3.027 update appears. However, no matter how many times I try, it remains at version 1.3.026. Even after downloading the file from the web and replacing the existing one, it still shows as version 1.3.026.
              Checking the details of the downloaded file also shows it as version 1.3.026.
              Could the download link for version 1.3.027 be broken?
              LIc. 0 OS10.15.8
              LIc. 1 OS15.8.3
                VectorStyler @861475_VctSt
                @861475_VctSt Will be fixed
                  I uploaded a fix for a bug, and the version is now 1.3.027
                    @VectorStyler said in update 1.3.026:
                    Thank you for fixing the bug. I had noticed the flip option copied the selection even when the option key was not used. That is fixed now!
                    • L Offline
                      Li Xiao @VectorStyler
                      this issue still requires further fixing.
                      There is still an issue across all UI input fields when typing in Chinese. After Chinese characters are committed via the IME, the text remains highlighted selected. As a result, subsequent keystrokes keep replacing previously entered text unless an arrow key is pressed to deselect it.
                      English input works as expected. This behavior only occurs on Windows tested across multiple Chinese IMEs with the same result and does not happen on MacOS.
                        VectorStyler @Li Xiao
                        @Li-Xiao said in update 1.3.026:
                        Do these issues occur when editing a text object on the canvas?
                        L 2 Replies Last reply Reply Quote 0
                        • L Offline
                          This issue does not occur on the canvas.
                          However, there are two bugs with vertical text Chinese and mixed Chinese English text on the canvas that need fixing. I will try to make time over the weekend to record a video demonstrating them.
                          • L Offline
                            @VectorStyler Two issues here: cursor positioning and its alignment with vertical text are broken
                            Vertical Text.vstyler
                            https://youtu.be/vapx7PBzOUc
                              This is a bug, I will try to fix it as soon as possible.
                              L 3 Replies Last reply Reply Quote 1
                              • L Offline
                                @VectorStyler Might as well make some improvements to Frame Text as well
                                https://youtu.be/_URRsQ_dk34
                                • L Offline
                                  @VectorStyler Vertical text still has a baseline deviation issue that needs improvement: when 'Automatic Vertical Roman' is enabled, letters and numbers deviate from the baseline.
                                  Vertical Roman.vstyler
                                  https://youtu.be/HnGOX77g3eE
                                  • L Offline
                                    @VectorStyler Another cursor bug in Vertical text (shown in the video): after deleting '竖排', the cursor sits between '2' and '3' instead of behind '3'.
                                    https://youtu.be/EVZW0RNx9Gc
                                      @Li-Xiao Can you send me the font used in this example. I could not replicate the problem with the fonts I have.
                                      • L Offline
                                        I only have around twenty Chinese fonts installed on my computer. After testing, only a few of them stay on the baseline, while the vast majority shift off it. These same shifting fonts do not deviate from the baseline in Illustrator or CorelDraw. Here are the download links for two free for commercial use Chinese fonts that reproduce this offset for your testing.
                                        https://github.com/Hansha2011/NanoTikBazHei/releases/tag/1.0
                                        https://github.com/feiyangjun-1/Sumr-Sans/releases/tag/0.1
                                        Vertical Roman 2.vstyler
                                        There are plenty of free for commercial use Chinese fonts available here: https://github.com/zispace/hanzi-fonts-ext
                                        • L Offline
                                          In version 1.3.032, testing with the roughly twenty Chinese fonts installed on my system shows noticeable improvement over before. Most are now just slightly off-center, leaning a tiny bit to the left. However, a Japanese font, Jigmo (https://kamichikoichi.github.io/jigmo/), is shifted way too far to the left.
                                          There are still issues with the cursor display and its placement.
                                          Arphic Chinese fonts are not working in VectorStyler, but they work fine in other apps.
                                          https://fonts.adobe.com/foundries/arphic-technology-co-ltd
                                          https://www.morisawa-arphic.com.tw/en/
                                          It would be much more convenient if a language filter could be added to font selection, just like in Illustrator or CorelDraw.
                                          Vertical Roman 3.vstyler
                                          https://youtu.be/qMvqE_eyfLI
                                            @Li-Xiao I will try to fix these
                                            • VectorStylerV VectorStyler moved this topic from Announcements and News
