Dragged JPEG becomes a gray rectangle after switching documents
Description:
An image dragged from a JPEG document into another document can become invisible and be replaced by a solid gray rectangle corresponding to its bounding box.
This is an old problem that had disappeared for several versions but appears to have returned.
Steps to reproduce:
Create a new document.
Open a JPEG as a document in VectorStyler.
Drag and drop the image from the JPEG document into the new document.
Create another new document.
Select the first new document to make it visible again.Result:
The dragged-and-dropped JPEG is no longer visible. Its bounding box is instead filled with solid gray. I have not found a way to make the image visible again.
Expected result:
The JPEG should remain visible when switching between documents.
I have attached the source JPEG used for the test and a VectorStyler document in which the problem occurred.VS_doc.vstyler
@jpsimmons I opened a bug on this and will try to replicate it.
@VectorStyler I can also give the pdf file that it will export with the blank bounding box in gray, as can be verified with other pdf viewers.
@jpsimmons send me to the same email address
@VectorStyler This is the pdf I get from File->Export->pdf.
Gray square shows up when I view it with Apple's Preview app.
I can send it via email if you like. Same address as the crash dump I sent earlier?
BTW: This isn't a fatal bug. I can still work by copy/paste. The drag and drop function is doing something odd.
