<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dragged JPEG becomes a gray rectangle after switching documents]]></title><description><![CDATA[<p dir="auto">Description:</p>
<p dir="auto">An image dragged from a JPEG document into another document can become invisible and be replaced by a solid gray rectangle corresponding to its bounding box.</p>
<p dir="auto">This is an old problem that had disappeared for several versions but appears to have returned.</p>
<p dir="auto">Steps to reproduce:</p>
<p dir="auto">Create a new document.<br />
Open a JPEG as a document in VectorStyler.<br />
Drag and drop the image from the JPEG document into the new document.<br />
Create another new document.<br />
Select the first new document to make it visible again.</p>
<p dir="auto">Result:</p>
<p dir="auto">The dragged-and-dropped JPEG is no longer visible. Its bounding box is instead filled with solid gray. I have not found a way to make the image visible again.</p>
<p dir="auto">Expected result:</p>
<p dir="auto">The JPEG should remain visible when switching between documents.</p>
<p dir="auto">I have attached the source JPEG used for the test and a VectorStyler document in which the problem occurred.<a href="/forum/assets/uploads/files/1784149109274-vs_doc.vstyler">VS_doc.vstyler</a> <img src="/forum/assets/uploads/files/1784149109330-potts-cleanvstyler-selection-withoutcropping.jpg" alt="Potts-cleanvstyler-selection-withoutcropping.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5863/dragged-jpeg-becomes-a-gray-rectangle-after-switching-documents</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 12:42:51 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5863.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Jul 2026 20:58:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dragged JPEG becomes a gray rectangle after switching documents on Thu, 16 Jul 2026 18:32:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jpsimmons" aria-label="Profile: jpsimmons">@<bdi>jpsimmons</bdi></a> send me to the same email address</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33646</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33646</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 16 Jul 2026 18:32:30 GMT</pubDate></item><item><title><![CDATA[Reply to Dragged JPEG becomes a gray rectangle after switching documents on Thu, 16 Jul 2026 18:25:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I can also give the pdf file that it will export with the blank bounding box in gray, as can be verified with other pdf viewers.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33645</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33645</guid><dc:creator><![CDATA[jpsimmons]]></dc:creator><pubDate>Thu, 16 Jul 2026 18:25:38 GMT</pubDate></item><item><title><![CDATA[Reply to Dragged JPEG becomes a gray rectangle after switching documents on Thu, 16 Jul 2026 05:55:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jpsimmons" aria-label="Profile: jpsimmons">@<bdi>jpsimmons</bdi></a> I opened a bug on this and will try to replicate it.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33644</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33644</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 16 Jul 2026 05:55:42 GMT</pubDate></item></channel></rss>
