Rounded corners regression after applying effect
Steps:
Draw a small rectangle and round all corners
Apply the drop shadow effect or any other effect
Now stretch the rectangle using the top/bottom/side (not the corner) transform handles
Notice the distorted corners (Refer to attached image).
@William-Kansepa Once an object has an effect like drop shadow, the transforms are applied over the final shape, resulting in distorted corner
@VectorStyler said in Rounded corners regression after applying effect:
@VectorStyler Thank you for the explanation.
However, in other software i.e. Illustrator, CorelDraw and Affinity, to mention but a few, such is not the case. The corners still remain perfect even after stretching the rectangle.Could something be done to address this challenge?
@William-Kansepa said in Rounded corners regression after applying effect:
I opened a bug on this and will try to find a solution, but it will be limited
Much appreciated. Thank you.
