<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rounded corners regression after applying effect]]></title><description><![CDATA[<p dir="auto">Steps:</p>
<li>
<p dir="auto">Draw a small rectangle and round all corners</p>
</li>
<li>
<p dir="auto">Apply the drop shadow effect or any other effect</p>
</li>
<li>
<p dir="auto">Now stretch the rectangle using the top/bottom/side (not the corner) transform handles</p>
</li>
<p dir="auto">Notice the distorted corners <em>(Refer to attached image)</em>.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1783753331836-distorted-corners.jpg" alt="distorted corners.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5857/rounded-corners-regression-after-applying-effect</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 09:39:21 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5857.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Jul 2026 07:02:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rounded corners regression after applying effect on Sat, 11 Jul 2026 08:31:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/33614">Rounded corners regression after applying effect</a>:</p>
<blockquote>
<p dir="auto">I opened a bug on this and will try to find a solution, but it will be limited</p>
</blockquote>
<p dir="auto">Much appreciated. Thank you.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33615</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33615</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Sat, 11 Jul 2026 08:31:30 GMT</pubDate></item><item><title><![CDATA[Reply to Rounded corners regression after applying effect on Sat, 11 Jul 2026 08:16:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> said in <a href="/forum/post/33613">Rounded corners regression after applying effect</a>:</p>
<blockquote>
<p dir="auto">Could something be done to address this challenge?</p>
</blockquote>
]]></description><link>https://www.vectorstyler.com/forum/post/33614</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33614</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 11 Jul 2026 08:16:30 GMT</pubDate></item><item><title><![CDATA[Reply to Rounded corners regression after applying effect on Sat, 11 Jul 2026 07:59:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/33612">Rounded corners regression after applying effect</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> Once an object has an effect like drop shadow, the transforms are applied over the final shape, resulting in distorted corner</p>
</blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thank you for the explanation.<br />
However, in other software i.e. Illustrator, CorelDraw and Affinity, to mention but a few, such is not the case. The corners still remain perfect even after stretching the rectangle.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33613</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33613</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Sat, 11 Jul 2026 07:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to Rounded corners regression after applying effect on Sat, 11 Jul 2026 07:41:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> Once an object has an effect like drop shadow, the transforms are applied over the final shape, resulting in distorted corner</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33612</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33612</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 11 Jul 2026 07:41:59 GMT</pubDate></item></channel></rss>
