    The behavior of the "remove color" button is strange.
    3 Posts 2 Posters 43 Views 2 Watching
    • 861475_VctSt8 Offline
      861475_VctSt
      I'm not sure when it started, but I've noticed strange behavior from the shortcut buttons in the color palette for some time, so I'm reporting it.
      Color settings are:
      Palette: Default CMYK
      Color: CMYK
      CMYK: Japan Color 2001 Corted
      Workflow
      I set the following on an object using the shortcut buttons in the color palette:
      Path: K100
      Fill: None
      The art display looks correct.
      The color palette displays:
      Indicator > Fill: None
      Slider > Fill: 50%
      In the Properties palette,
      However,
      Slider > Fill: C47, M38, Y39, K3
      It seems that the interpretation of Fill: None and Color: 0 is not working correctly.
      LIc. 0 OS10.15.8
      LIc. 1 OS15.7.4
        VectorStyler @861475_VctSt
        @861475_VctSt The problem is that it tries to show a color for the Fill (in this case the stroke does not affect it).
        I will try to fix this
          861475_VctSt @VectorStyler
          Thanks
          It finally cleared up the confusion I’ve been feeling for years.
          LIc. 0 OS10.15.8
          LIc. 1 OS15.7.4
