<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The behavior of the &quot;remove color&quot; button is strange.]]></title><description><![CDATA[<p dir="auto">I'm not sure when it started, but I've noticed strange behavior from the shortcut buttons in the color palette for some time, so I'm reporting it.</p>
<p dir="auto">Color settings are:<br />
Palette: Default CMYK<br />
Color: CMYK<br />
CMYK: Japan Color 2001 Corted</p>
<p dir="auto">Workflow</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1778036829064-sc2026-05-05-15.57.07.png" alt="SC2026-05-05 15.57.07.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I set the following on an object using the shortcut buttons in the color palette:<br />
Path: K100<br />
Fill: None</p>
<p dir="auto">The art display looks correct.</p>
<p dir="auto">The color palette displays:<br />
Indicator &gt; Fill: None<br />
Slider &gt; Fill: 50%</p>
<p dir="auto">In the Properties palette,<br />
Indicator &gt; Fill: None</p>
<p dir="auto">However,<br />
Slider &gt; Fill: C47, M38, Y39, K3</p>
<p dir="auto">It seems that the interpretation of Fill: None and Color: 0 is not working correctly.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5761/the-behavior-of-the-remove-color-button-is-strange.</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 10:26:36 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5761.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 May 2026 03:07:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to The behavior of the &quot;remove color&quot; button is strange. on Wed, 06 May 2026 04:37:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/861475_vctst" aria-label="Profile: 861475_VctSt">@<bdi>861475_VctSt</bdi></a> The problem is that it tries to show a color for the Fill (in this case the stroke does not affect it).<br />
I will try to fix this</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33174</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33174</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 06 May 2026 04:37:01 GMT</pubDate></item></channel></rss>
