VS not printing at all.
  • Hi. Im trying to print from VS. It show the preview correctly, but dont print nothing. The paper just run out empty. I dont have this problem with any other software.
    Im using a simple home printer, an EPSON L395. The printer have an internal preview setting that allow you to see how it will be printed on screen, before the printing on paper. That setting is also ignored. The paper run out empty.
    So, i thought i will print in a PDF printer. I have several installed, Microsoft print to PDF, PDF24, etc.
    Paper is blank, empty. So, is not an issue related to the physical printer. If i "print to pdf", the result file is ok.
    @marce I opened a bug on this. Printing was tested very recently, and it has been working.
    Could be a regression.
