    Bug List for Version 1.3
    124 Posts 4 Posters 18.6k Views 4 Watching
      monsterfox @VectorStyler
      @VectorStyler 10.Using the mirror group and enabling the crop section will cause errors when expanding the graphics2_1765204810870_mmexport1765204406094.jpg 1_1765204810860_mmexport1765204403505.jpg 0_1765204810827_mmexport1765204401722.jpg
        VectorStyler @monsterfox
        @monsterfox I added this to the backlog. Can you send me the file with the cropped mirror, just before expanding? Thanks!
          @VectorStyler 0_1765253433296_3_66.vstyler
            @VectorStyler 11,Paths without color information still cannot be imported or exported.
            Hope this issue can be fixed.
              I will review this how it is done in other apps, but in VS this is by design, if a shape has no style, then it is not exported to vector formats
                Can be replicated, will be fixed in the next build
                  @VectorStyler Error 1 Addendum: DXF files can now be imported, but there are still a few issues: 1. The imported DXF file does not have the correct size. 2. Dragging the provided file into the canvas converts it into an image. 3. The DXF file exported by VS also has an incorrect size, which is larger than the original file. These issues need to be fixed.
                  https://youtu.be/WRUsV2ZrsAc?si=4HZ9Wf5hfPOux_Fj
                  https://youtu.be/HZpdocZXR0g?si=pw3XJ6jDU637AThx
                  0_1765467212712_Picture.DXF.zip
                    @VectorStyler Error 5 Addendum: Several incomplete translations have also been found.
                    1_1765467480521_mmexport1765467415023.png 0_1765467480498_mmexport1765467402750.jpg
                      @VectorStyler !
                      12. The display of the selected object count is incorrect. When multiple objects are selected, it shows their respective layer names instead of the selected quantity statistics.
                      1_1765467598767_mmexport1765467529879.jpg 0_1765467598750_mmexport1765467523415.jpg
                        @VectorStyler Error 3 Addendum: Now the individual move transformation is usable, but its effect is quite different from that before version 1.2. In version 1.2, when multiple objects have overlapping values, the shape with the largest area is moved first, followed by others in descending order of area. In version 1.2, errors occurred when operating complex groups, resulting in shape offset and confusion. In the current version 1.3, it is bundled with randomization, which undermines the practicality of this function. We still hope this issue can be resolved.
                        https://youtu.be/UQOK05KPfrM?si=eVtkkI2HO2nSTOEW
                          @VectorStyler Error 8 Addendum: This function now supports converting regular paths, but it still cannot match the angle of the original shape. The example in my figure is a rounded rectangle from a sketch. When trying to convert it to a regular rectangle, the resulting rectangle is only generated based on the width and height. This is not the expected result, and we hope this issue can be resolved.
                            @VectorStyler 1_1765469312130_mmexport1765469232574.png 0_1765469312112_mmexport1765469235264.jpg
                            13. The options for copying and pasting object dimensions cannot be found in the shortcut menu, and they need to be added.
                              If a document was saved while using the English UI, then some text will be in English. These names (customizable by the user) are stored in the document, not by the current language.
                                If randomization is disabled, what would the difference between "Transform Each" or normal move be?
                                  @VectorStyler When multiple objects are selected: 1. A normal move shifts all objects by the same distance synchronously. If the patterns are stacked initially, they remain stacked after moving. 2. When "Transform Each" is checked, multiple objects move with increasing parameters, resulting in them being separated in the end. Example: Select three objects, align them center horizontally and vertically, then set the move parameter to 10. The first object moves by 10, the second by 20, and the third by 30. Their movement order is determined by the size of the objects. This operation would greatly enhance usability, and we hope this feature can be added.
                                    I will try to implement this.
                                      @VectorStyler The issue where DXF files were imported as images has been resolved. There are still two remaining problems: 1. The imported images are not in the correct size. I have provided two types of files, one that becomes larger and one that becomes smaller. 2. All exported DXF files will increase in size. These two issues need to be fixed. Additionally, an AI file in the compressed package cannot be imported either.
                                      0_1765636913759_DXF+AI.zip
                                        @VectorStyler The "Copy Object Dimensions" option has been added to the shortcut menu, but the "Paste Object Dimensions" option is missing. Please fix this.
                                          Will be added
                                            @VectorStyler Error 10 added: Currently, mirror groups support expansion, but the expanded result is not as expected. I have communicated this issue with Li Xiao, and we both agree that the optimal expanded result should be the united state of the objects. Those masks are not very useful; please fix this problem.
