Displacement issue
When the Displacement source is a text on path object, the generated result is incorrect, it behaves the same as when the path text is released. It only works correctly after converting the path text to curves.
@Li-Xiao I opened a bug on this. The problem is that shape effects are calculated before text on path links.
I will try to find a solution
@VectorStyler said in Displacement issue:
I will try to find a solutionThanks! The path text is linked to a data source, but once it’s converted to curves, the text can no longer be variable.
@VectorStyler fixed(1.2.090), thanks
