    Support a Blob type of vector brush
    38 Posts 6 Posters 16.2k Views 5 Watching
      Boldline @Boldline
      @VectorStyler I noticed that it would sometimes work depending on what I was clicking overtop of. Then eventually I lost my custom shape path brush entirely and it went back to being a default circle.
      Link to new video showing this
        Boldline @Boldline
        Update: I tried this on my laptop running default settings and had the same issues.
        The shape only seemed to work when i was touching an existing shape. in my case here, the shape somehow changed mid-use and merged another star into itself....
        0_1758131671558_95ba5a1e-c881-4a69-b50c-22fcfe488376-CleanShot 2025-09-17 at 13.47.36.png
          Subpath @Boldline
          its not your fault, got the same behaviour
          it seems a bug
          a single Blob could only set with the
          default circle blob
          all blobs shape made via the "Shape" Role
          works only if paint with it and then single blobs can
          be set if there is a kind of overlapping. They dont work
          as single blobs
          • B Offline
            Bitten
            Hey all thanks for the responses, I can't find anytool called a path brush tool in the ui of the version downloaded if it is in there, it's well hidden.
            I made a video to try help explain what exactly this freeform paint style tool can do
            https://youtu.be/6JAoFnc9-Zk?t=367
            The ability to erase parts of it as well is also as important as the painting.
            Devil DinosaurD 1 Reply Last reply Reply Quote 0
            • Devil DinosaurD Offline
              Devil Dinosaur @Bitten
              @Bitten
              Hi,
              Like said above, what you need is the "Path Brush Tool". It's located on the left main tool bar, third icon from the top, then the last of the menu that opens to the right. It's pressure sensitive and seems to be what you want. You may check some other tools of this section.
              Fred.
                I noticed two additional things:
                First:
                I miss a live preview when changing the size of the Path Brush tool.
                The brush tip size only changes after I've set a new size. This
                makes adjusting the size a bit unintuitive.
                Second:
                No matter which shape you select as the brush tip, the Path Brush
                tool always paints with a rounded tip. This makes changing the
                Brush tip somewhat useless.
                I also demonstrate both of these points in this video.
                  VectorStyler @Subpath
                  @Subpath said in Support a Blob type of vector brush:
                  When painting with the brush (not clicking) the top is always rounded.
                  Only when clicking you can use the selected shape
                  S BoldlineB 2 Replies Last reply Reply Quote 0
                  • B Offline
                    Bitten @Devil Dinosaur
                    @Devil-Dinosaur Ok nice yeah I found the brush tool now and it does seem to work a lot like the other tools mentioned which is great. One big issue with it right now though as I think Subpath also calls out is that the pressure changes you make don't adjust the size of the "preview / cursor" until you release.
                    What this results in is a situation where it's difficult to know if you have actually painted in a filled area on your canvas till you release the pen from screen, often showing that actually there are little gaps because pressure wasn't hard enough, This also makes it hard to do fine pen work because the preview is max brush size not the actual brush size with pressure factored in.
                    So I think in summary Yes there's a brush tool that can let you draw as shapes, and an eraser to go with it but both tools seem geared for use with a mouse not pressure pen as the brush size indicator does not adjust to match actual brush size when laying down new pressure based strokes
                      Subpath @VectorStyler
                      Yes, I know that and I have already mentioned it,
                      but I find this behavior a bit curious
                      • E Offline
                        EricP
                        @Subpath thanks for the tip about shape nib.
                        I had tried earlier to change the shape on the toolbar when the path brush tool was active, but all it did was to replace the selected object by the shape, not change the brush nib.
                        Watching your video, I now understand that the shape must be selected with no canvas object selected so it can change the nib shape. Thanks
                        But using the feature, it doesn't apply the shape when dragging the path brush. It only seems to apply it when clicking on the border of an object, it then modifies the object shape with the selected tool shape.
                        Not very intuitive but still useful
                          Subpath @EricP
                          @EricP
                          You're welcome.
                          I also find it strange that you can't paint with the path brush tool
                          using the selected shape tip.
                          Btw. this option to select a shape that have previously been
                          assigned the shape role is available for many tools in VectorStyler,
                          you can always check to see if a shape selection is offered in the
                          setting of a tool.
                          You can also use this to create shape presets, for example. You
                          can also do this with the parametric shapes in VS, which remain
                          editable.
                          Here a video where change a shape used in a blend
                          E 1 Reply Last reply Reply Quote 1
                          • E Offline
                            EricP @Subpath
                            @Subpath thanks for these tips.
                            Yes, I've tried to change the shape of some tools like the "Shaped Bump Tool" but did not find it to work as expected. Maybe I missed how to use it properly.
                            Coming back to the Path Brush tool, I really like what can be obtained with it, to imprint some patterns on the surface of shapes.
                            I experimented a bit and tried some modifier keys with it. I was hoping Alt would turn it into a Path Eraser but it doesn't.
                            However, a cool modifier is Shift, where if you shift-click with Path brush tool on a shape (doesn't have to have a shape role), the nib takes that shape. You can repeat over and over and get some kind of fractal construction where the path embeds smaller versions of itself.
                            here is an example : https://somup.com/cTQFl7P10Y
                              @VectorStyler said in Support a Blob type of vector brush:
                              Is there a reason you don’t want to have it operate in that manner? From my perspective, I would find that option very useful. A lot of interesting things could be done if the painting aspect used the shape and was not just the default rounded.
                                @Boldline said in Support a Blob type of vector brush:
                                When paining with the path brush, an expanded outline shape is created (calligraphy and variable width included).
                                But there is no method to using an arbitrary shape in this process. It is just no way to "define" it, unless I do some hacking.
                                E S 2 Replies Last reply Reply Quote 1
                                • E Offline
                                  EricP @VectorStyler
                                  @VectorStyler It's not the way it's working today but I agree with @Boldline it would be great to be able to "paint" with a shape
                                  The way I imagine it is you drag the mouse and VS inserts+merges shapes continuously (at intervals), like if you were clicking after each small position offset
                                  like this : https://somup.com/cTQF2FP1a9
                                    I don't think any user here would want to pressure you into any kind
                                    of hacking. Is just we don't know in full the mechanism behind.
                                    As for me, I can live with the current situation. Once I know how
                                    something works, i have no problem to act accordingly.
                                      Subpath @EricP
                                      @EricP
                                      ... However, a cool modifier is Shift, where if you shift-click with Path brush tool on a shape (doesn't have to have a shape role), the nib takes that shape. You can repeat over and over and get some kind of fractal construction where the path embeds smaller versions of itself ....
                                      Interesting, did not know that.
                                      • B Offline
                                        Bitten
                                        Put a video together to better show the 3 main problems with this software still
                                        https://youtu.be/Pb7otS5bovU
                                        It's definitely close but right now not quite where it needs to be.
                                          VectorStyler @Bitten
                                          @Bitten What kind of tablet is used there?
                                          • B Offline
                                            Bitten @VectorStyler
                                            @VectorStyler Wacom Movink 13
