Graphic production?
@Jono Is this AD file the final effect? Can you share it? I'd like to know the detailed production details, thank you.
@monsterfox Here's the method I used...
@Jono Thank you. Your method uses circles to create a blending effect. It's simple, but requires stitching and is a bit tedious.
Achieving this metaball/Truchet tile effect seems like the easiest step to take.
To get that halftone effect too is, at least, where my brain stop working.
@Li-Xiao , did a Tutorial a while ago which works via the Repeater.Here the Link
https://www.vectorstyler.com/forum/topic/3915/creating-a-truchet-tiles-using-repeater
Just for inspiration. Here's a video from the Paragraphic YouTube
channel showing how to create a similar pattern. I mentioned Paragraphic
in another tread already.A search on Youtube "Metaball pattern", "Blob Pattern", "Truchet pattern"
may also be helpful.
@Subpath https://youtube.com/shorts/gHN57OiFCTs?si=RXZYx0E6eMVNJkNq
Maybe Li Xiao's method is indeed needed to complete this. Your information is very helpful. It's likely a combination of halftone and Truchet pattern. You can also take a look at that video.
@monsterfox said in Graphic production?:
Yes, doing things that way would be time consuming to say the least!
I'm going to look at the Repeater videos and resources (thanks Li-Xiao). I know I'm missing out so much of what VS can really do.
No need to worry
Even if you know much more about VectorStyler
you will still miss Features.Because its such a deep rabbit hole
@Subpath This damned program—I’ve been using it for a year, and the more you use it, the more you realize there’s so much you don’t understand. I’ve never come across this in any other program. It’s a bottomless pit, haha.
Because I like to explore, find new things, new paths, and be surprised.
I am in heaven with VS.
@Subpath Okay, if explorers find any interesting features, remember to share them. I'm following in your footsteps.
