Snapping forces orthogonal
Why when I enable snapping the lines are forced to orthogonal direction, even though I didn't enable the option?
@Fertuffo I tried to replicate this, but with snapping enabled, I can draw lines in any direction.
Which snapping option was enabled?
Maybe a recording might help.
@Fertuffo I set the same options, but I still could not replicate it, here is how I have it: https://share.cleanshot.com/m2mG79yj
is the Shift key held while using the Pen tool? than can cause this.
Otherwise, try reseting all settings / workspace to the defaults.
@VectorStyler Resetting to default workspace worked just fine.
Is there a way to temporarily disable the ortho/45 degree snap? I noticed that this feature is very useful but in some cases can cause problems when snapping to nearby points.
Thank you
@Fertuffo I have to correct myself. After creating a new document, the problem reoccurs. Resetting the workspace now does not solve the problem anymore.
The snapping system has been behaving very strangely lately
@Fertuffo Send me by email your settings / workspace files.
Ok.
The problems seemed to be solved when I saved my custom settings to a file. Oddly enough, after some time of working, the snapping started to go crazy again.
I'll send you my settings anyway.
Thanks
@Fertuffo Got the workspace files, but still could not replicate it.
I opened a bug on this and will try to find out what could cause this kind of problem.
@Fertuffo if the "Allow Snapping" (in Snapping panel) is disabled, then is there an issue?
@VectorStyler said in Snapping forces orthogonal:
no issues when "Allow snapping" is disabled.
I'm not having any problems at the moment with the snapping. I'll let you know.
Thanks
