A suggestion about alignment
Hello friends,
Changes the order of the elements in a different direction when we add the spacing according to the key object.
Yours sincerely
Hakan Balcı
@hbalcic I added this to the backlog, will get back with questions later.
I set it up in AI. That's how it's supposed to work:
@VectorStyler It can be seen that the order of the graphics has changed (it is necessary to prompt that the error of order change will also occur when multiple objects are arranged along the path). Please fix it as well.
‘Key Objects’ commands belong to ‘Distribute’. Wrongly linked to ‘Align Positions’ commands. Works with the ‘Space’ command.
@hbalcic I noticed this also. I can't get it to work at all as expected (Distribute).
@hbalcic Thank you for providing this file for quick testing!
This is maybe a bug, but I noticed it opened this way... will have to click to zoom in, but check the Ruler measurements... I think I did Zoom to Artboard to get it where it needed to be.
@hbalcic said in A suggestion about alignment:
The "Key Objects" option should also work with the align positions
