Repeater
1:https://youtu.be/82p_1su7ij0?feature=shared The Repeater does not support releasing multiple graphics simultaneously. After release, the graphics will be lost. Moreover, it is impossible to undo and restore.
2:https://youtu.be/UhyaPdWcZyM?feature=shared After the graphic is generated in the Repeater, move the position of the Repeater graphic. Then release the graphic. As a result, the graphic is still in the originally generated position instead of the current position.
@monsterfox Can you send me those files.
@VectorStyler The problems in Video 2 haven't been fixed yet.
@monsterfox I will try to fix that too
@monsterfox This issue should be fixed in build 1.2.046
@VectorStyler I've noticed it. Thank you for the fix.
When the Repeater uses these two parameters simultaneously, the graph will become chaotic.
@monsterfox That is mean to be, and it is not chaotic, just a more complicated pattern.
@VectorStyler This error of mine should be the same as Lixiao's.
https://www.vectorstyler.com/forum/topic/4356/repeater-s-shift-issue
@monsterfox That is bit different. The variation in the dot size, in combination with the two shifts caused a regular pattern.
But yes, that is also still happens (no fix yet).
@VectorStyler When operating multiple Repeaters simultaneously for Expand Repeater, an error will occur. The graphics will be lost, and there is also a problem that cannot be undone.
@monsterfox said in Repeater:
I opened a bug on this.
Can you send me an example file for this error? Thanks!
@VectorStyler The files in this post can be used. It has been experimented and there will be errors. They are on the third floor.
@monsterfox I tried with the file that was uploaded in this thread, but the only issue I find is that the selection is lost. Undo is working.
@VectorStyler https://youtu.be/YfQfUv2k-e4?feature=shared
The actual situation here with me is the video effect.
