    graphic replacement any Reference
    7 Posts 2 Posters 6.2k Views 2 Watching
    • M Online
      monsterfox
      1:https://youtu.be/jbazROFD6uY?feature=shared
      2:https://youtu.be/PsuBQF1em_I?feature=shared
      Video 1: 1. The shape above is the replacement source, and the path below is the object to be replaced. Shrink the replacement source by a certain percentage value, and the object after replacement will be the original size of the source (if converted into a curve, no error will occur). This needs to be fixed here. 2. Undo the above operation several times, and two identical shapes will appear below.
      The error in video 2 is quite obvious when watching the video. It should be noted that for the original figure, rotation, skew, mirroring, other figures will have movements, but moving the original figure will not result in any movement.0_1729091769430_2.vstyler
      0_1729091797977_kelong.vstyler
      VectorStylerV 3 Replies Last reply Reply Quote 1
        VectorStyler @monsterfox
        @monsterfox I will try to replicate and fix these.
          @monsterfox In Video 2: you need to group the objects before doing a reference to create a "common" reference. Otherwise a lot of smaller references are created and relative movements are not applied.
          Reason: cannot move a reference if a source is moved, since references must have independent positions.
            @monsterfox I cannot replicate the steps in Video 1 (probably you have different shortcuts).
            Can you please explain the steps.
            • M Online
              monsterfox @VectorStyler
              @VectorStyler There is a history record nearby. Can't it be operated while viewing the record?
                @monsterfox In video 1 at 1:28, a shape is selected (I presume), what command was used for this?
                • M Online
                  @VectorStyler That is the left - side graphic replacement tool.
