<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[graphic replacement any Reference]]></title><description><![CDATA[<p dir="auto">1：<a href="https://youtu.be/jbazROFD6uY?feature=shared" rel="nofollow ugc">https://youtu.be/jbazROFD6uY?feature=shared</a><br />
2：<a href="https://youtu.be/PsuBQF1em_I?feature=shared" rel="nofollow ugc">https://youtu.be/PsuBQF1em_I?feature=shared</a><br />
Video 1: 1. The shape above is the replacement source, and the path below is the object to be replaced. Shrink the replacement source by a certain percentage value, and the object after replacement will be the original size of the source (if converted into a curve, no error will occur). This needs to be fixed here. 2. Undo the above operation several times, and two identical shapes will appear below.<br />
The error in video 2 is quite obvious when watching the video. It should be noted that for the original figure, rotation, skew, mirroring, other figures will have movements, but moving the original figure will not result in any movement.<a href="/forum/assets/uploads/files/1729091771660-2.vstyler">0_1729091769430_2.vstyler</a><br />
<a href="/forum/assets/uploads/files/1729091800325-kelong.vstyler">0_1729091797977_kelong.vstyler</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4704/graphic-replacement-any-reference</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 06:41:44 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4704.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Oct 2024 15:16:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to graphic replacement any Reference on Fri, 18 Oct 2024 14:46:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> That is the left - side graphic replacement tool.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27436</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27436</guid><dc:creator><![CDATA[monsterfox]]></dc:creator><pubDate>Fri, 18 Oct 2024 14:46:38 GMT</pubDate></item><item><title><![CDATA[Reply to graphic replacement any Reference on Fri, 18 Oct 2024 13:09:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/monsterfox" aria-label="Profile: monsterfox">@<bdi>monsterfox</bdi></a> In video 1 at 1:28, a shape is selected (I presume), what command was used for this?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27435</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27435</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 18 Oct 2024 13:09:29 GMT</pubDate></item><item><title><![CDATA[Reply to graphic replacement any Reference on Fri, 18 Oct 2024 13:01:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> There is a history record nearby. Can't it be operated while viewing the record?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27434</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27434</guid><dc:creator><![CDATA[monsterfox]]></dc:creator><pubDate>Fri, 18 Oct 2024 13:01:09 GMT</pubDate></item><item><title><![CDATA[Reply to graphic replacement any Reference on Fri, 18 Oct 2024 11:50:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/monsterfox" aria-label="Profile: monsterfox">@<bdi>monsterfox</bdi></a> I cannot replicate the steps in Video 1 (probably you have different shortcuts).</p>
<p dir="auto">Can you please explain the steps.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27432</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27432</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 18 Oct 2024 11:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to graphic replacement any Reference on Fri, 18 Oct 2024 11:44:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/monsterfox" aria-label="Profile: monsterfox">@<bdi>monsterfox</bdi></a> In Video 2: you need to group the objects before doing a reference to create a "common" reference. Otherwise a lot of smaller references are created and relative movements are not applied.</p>
<p dir="auto">Reason: cannot move a reference if a source is moved, since references must have independent positions.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27431</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27431</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 18 Oct 2024 11:44:58 GMT</pubDate></item><item><title><![CDATA[Reply to graphic replacement any Reference on Wed, 16 Oct 2024 15:39:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/monsterfox" aria-label="Profile: monsterfox">@<bdi>monsterfox</bdi></a> I will try to replicate and fix these.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27425</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27425</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 16 Oct 2024 15:39:32 GMT</pubDate></item></channel></rss>
