    Issue with the interface
    30 Posts 4 Posters 48.1k Views 3 Watching
      VectorStyler @B-Vs-V
      @Pat Did it reset to defaults? or is it not showing?
      The user data folder (Help -> Workspace Folder) contains the files where all the UI state is stored.
      If there are problems you could remove these and try launching again.
      • B Offline
        B-Vs-V @VectorStyler
        @VectorStyler Not showing.
          @Pat Find the folder: c:\Users<user name>\AppData\Local\NumericPath\VectorStyler1.2\vector\
          Back up the data folder (also contains presets) and the remove it.
          • B Offline
            @VectorStyler Since these UI issues appeared, I save some worskpaces and simply reinstall one. For now, the interface remains stable, thanks ☺
              Boldline @B-Vs-V
              @Pat said in Isue with the interface:
              I know that without being able to reproduce it, it won't be very useful to mention it, but I lost my interface again when I reopened VS. I'd already had this problem with version 1.1: no toolbar and almost no panels.
              I had this exact issue happen to me yesterday on my M1 mac mini. I was using the eyedropper tool and after some use, the cursor icon disappeared and the eyedropper task itself was not functioning properly. trying to switch tools and rotating with the transform tool also did not show the cursor icon at all. I saved my file and quit VS and when it reopened, I was missing toolbars and my workspace and settings files were no longer installed, nor were they options to switch to like before. The toolbar, contextual menu and iconized menu on the right side were all gone and each had to be turned back on manually.
                @Boldline When this happens, send me all the workspace files.
                • debraspicherD Offline
                  debraspicher
                  I have the opposite problem. My interface elements have doubled. 😆
                  Fun fact: The toggle UI feedback only works on some of the UI elements when this happens.
                  I linked a video and if you notice it loads in the center of the screen and then that splash screen scales down UI wise. So it may be "redoing" the layout without cleaning up and thus creating duplicates. Maybe? Loading the "Default" workspace still ends up with doubles.
                  Video of behavior:
                  https://1drv.ms/v/s!AuWHX0h5bAoRifU9f2cCi_uxRcEijA?e=yzAUzQ
                  Workspace files:
                  0_1712973896996_workspace-files.zip
                  I deleted the contents of the folder with VS closed and reopened. Seems fine now.
                  32GB RAM @ 6000MHz
                    VectorStyler @debraspicher
                    @debraspicher I try to find out what caused this. Was there a workspace loading / resetting when the docked panels doubled?
                      debraspicher @VectorStyler
                      @VectorStyler I wish I could be of more help. They opened with the program panels doubled. If you have any suggestions how to debug or where to begin monitoring, then I could keep an eye on it for when it happens again.
                      32GB RAM @ 6000MHz
                      • B Offline
                        @VectorStyler said in Isue with the interface:
                        @VectorStyler this is a recurrent issue. I've tried restoring the default VS workspace but to no avail. Fortunately, the workspace I had saved is still functional ☺
                          I tried to replicate this here, but soft far here it has been working.
                          Send me those workspace files (including the settings), and I will try with those.
                          • B Offline
                            @VectorStyler Files sent ☺ Thanks.
                            • B Offline
                              @VectorStyler I forgot to mention that I saved workspaces in a directory on my DD which is in fact synchronized on an external server managed by my Institution. I don't know whether this has any impact?
                                Should not have any impact.
                                  debraspicher
                                  I haven't figured out a trigger for this, but I've been trying. Occasionally I will go back to VS and the UI will be in this state.
                                  Video link below... (LOUD music warning: I'm sorry in advance for the music, I forgot my headphones were toggled in OBS):
                                  https://1drv.ms/v/s!AuWHX0h5bAoRifY14BXgOVp8BGU-Pg?e=T61kp9
                                  Restoring using View>Workspaces>"Default Workspace" gets us back in business, so it's not like the defect from before where I had to clean out the WS folder. But perhaps that was a result of me closing the program after the issue occurs? (I'll try again later...)
                                  This has happened twice so far and these UI issues always occur when I go back into VS after a break while it was running in the background. I lock my PC at night so my monitors will shut off and leave it running overnight, so maybe something awful occurs when my displays wake back up. Perhaps if I stop leaving it up when my displays go idle it will stop occurring?...
                                  32GB RAM @ 6000MHz
                                    debraspicher
                                    I can confirm when VS is closed with a "corrupt" interface without reloading the Default, it apparently saves itself as the new default. I followed @Pat's solution and had a WS saved in case which I used to get back the original state. Video: https://1drv.ms/v/s!AuWHX0h5bAoRifY4lt8pfV_Rsi3QjQ?e=WFdylB
                                    Once again, this issue appeared again when I left the PC on idle (monitors off).
                                    32GB RAM @ 6000MHz
                                      @debraspicher said in Issue with the interface:
                                      Can you save a workspace when VS is in this broken state, and send me the workspace file? I would like to replicate this.
                                      Also: the detached context panel is not really a bug (it can be detached by dragging).
                                      But the document tap showing at the bottom is a bug.
                                      • B Offline
                                        B-Vs-V
                                        Over and over again... This time, VS didn't like me testing the Shape builder tool on a previously edited object. VS got "tangled" and I ended up with the same minimal interface. I downloaded a saved WS and had to redo it after closing and reopening the software. Again, the problem is to reproduce this issue. I hadn't thought of saving my last WS, better to do it.
                                        • B Offline
                                          @VectorStyler Still happening in 1.2.049 ☹
                                            @B-Vs-V Somehow I will need to replicate this. Did this look similar to earlier screenshots?
