    Regarding the halftone repeater types
    76 Posts 6 Posters 204.7k Views 4 Watching
    • L Offline
      Li Xiao @VectorStyler
      @VectorStyler Just as shown in the image.
        VectorStyler @Li Xiao
        @Li-Xiao Send me the file with the original repeater (first image).
        • L Offline
          example
          0_1711881513153_Apply Shape Effects.vstyler
            @Li-Xiao There is a bug here, I will try to fix it ASAP.
            L 3 Replies Last reply Reply Quote 1
            • L Offline
              @VectorStyler Thank you, it turns out it was a bug. I had mistakenly thought it wasn't supported, which is why I was wondering if there could be a non-destructive expansion feature.
              • L Offline
                Halftone based on the corresponding grayscale values according to the area size. I used four objects as an example, because performing calculations on multiple objects in CD's VBA is too slow.
                0_1711908024378_Area Halftone.pdf
                I tried using Repeater but couldn't achieve it. You can watch a video demonstration.
                https://youtu.be/BRDstB4hbFs
                • L Offline
                  There are many small apps available that can create wave halftones. I have selected three for your reference.
                  1. SquiggleDraw
                    SquiggleDraw will create a SVG file from an image, using the brightness to change the amplitude of sine waves.
                    SquiggleDraw is free and unencumbered software released into the public domain.
                    https://github.com/gwygonik/SquiggleDraw
                    Recorded video
                    0_1712504072373_SquiggleDraw.svg
                  2. Makelangelo
                    Makelangelo Software is a Java program that prepares art for CNC plotters. It was originally designed for the Makelangelo Art Robot. It runs in Windows, OSX, and several flavors of linux.
                    Makelangelo is free too.
                    https://github.com/marginallyclever/makelangelo-software/
                  Recorded video
                  0_1712504704342_Makelangelo.svg
                  1. DrawingBotV3
                    DrawingBotV3 is a software for converting images to stylised drawings with many applications including Pen Plotter Art, Digital Artwork, Image/Video Stylisation, NFT Creation, Embroidery and Graphic Design. With an intuitive User Interface allowing both Beginners and Advanced users to create beautiful artwork without any programming knowledge. Featuring over 50 in-built styles which are all highly customisable, the possibilities are endless!
                    There are two versions, Free and Premium. I previously purchased the Premium version.
                    The Free version is Open-Source
                    The Premium version is Closed-Source
                    Both versions are available for Windows, Mac and Linux.
                    https://github.com/SonarSonic/DrawingBotV3
                    Recorded video
                  0_1712506173040_DrawingBotV3 - Hatch Sawtooth.svg
                  0_1712506181339_DrawingBotV3 - Hatch Circulaar Scribbles.svg
                  BoldlineB VectorStylerV 2 Replies Last reply Reply Quote 2
                    Boldline @Li Xiao
                    @Li-Xiao I appreciate all the testing and experimentation you've been doing with the repeater tool in VS. It's such a powerful tool and I can imagine how much better it will be when the improvements listed in the roadmap for repeater are implemented. No doubt your hard work will pay off and hep expand what repeater is capable of
                      @Li-Xiao Interesting patters. There will be a bit of improvement regarding this in the next build.
                      L 2 Replies Last reply Reply Quote 4
                      • L Offline
                        Blend Halftone is a halftone effect that blends two shapes together. One shape corresponds to 0% grayscale value, while the other shape corresponds to 100% grayscale value. The shapes in between blend to represent grayscale values from 1% to 99%. If multiple shapes are blended, each shape corresponds to its respective grayscale value based on the blending proportions.
                        0_1712564707579_Blend Halftone.pdf
                          Subpath @Li Xiao
                          @Li-Xiao
                          looks interesting and "DrawingBot" too !
                          btw like to contribute something to this which is Nodebox
                          related. It cannot compete with either DrawingBot or the Repeater.
                          I found out that NodeBox also allows to do some things along
                          those lines.
                          This works because you can create your own nodes in NodeBox.
                          With the Python program language and expand the Nodes command set
                          this way.
                          John from the NB Forum support team created an image node
                          which can be downloaded here this Link shows also some Results.
                          http://support.nodebox.net/discussions/show-your-work/400-image-node
                          here a example
                          • L Offline
                            Li Xiao @Subpath
                            @Subpath The image nodes in Nodebox are also fascinating. Drawingbot also has a node-based version, currently in its Alpha phase.
                              Subpath @Li Xiao
                              @Li-Xiao
                              thanks, will keep an eye on that
                              ...The image nodes in Nodebox are also fascinating...
                              yes, and to be able to create your own Node add yet another Level to this
                              John from NB Forum, create the most of the user defined Nodes
                              he made also a whole little Library ( free to use ) which can be found here
                              http://support.nodebox.net/discussions/show-your-work/698-cartan-node-library-33
                              the library comes with a PDF Doc
                              • L Offline
                                Voronoi Halftone is fascinating. I know a few free online generators for it, but most only support output as bitmaps. Let me recommend one that I particularly like, which supports PNG input and SVG output, but it has a seeds limit of 800.
                                https://github.com/WebSVG/voronoi?tab=readme-ov-file
                                https://voronoi-editor.web.app/
                                Parametric Voronoi generator with real time editing and SVG export.
                                Recorded Video
                                sample files:
                                0_1712680642375_Voronoi_1.svg
                                0_1712680659017_Voronoi_2.svg
                                0_1712680680064_Voronoi_3.svg
                                0_1712681201696_Voronoi_4.pdf
                                Drawingbot also offers three variations of the same type.
                                https://docs.drawingbotv3.com/en/latest/_images/voronoi_diagram_1.jpg
                                https://docs.drawingbotv3.com/en/latest/_images/adaptive_diagram_1.jpg
                                https://docs.drawingbotv3.com/en/latest/_images/lbg_diagram_1.jpg
                                some voronoi gallery
                                https://www.josleys.com/show_gallery.php?galid=284
                                  @Li-Xiao said in Regarding the halftone repeater types:
                                  Yes, this is really nice. But for now this will not be possible. Maybe in later versions.
                                    @Li-Xiao
                                    Because of the Voronoi pattern, I thought of the Java programming language
                                    โ€œProcessingโ€. which was developed specifically for graphical applications.
                                    There are some examples on โ€œOpenprocessingโ€ of Voronoi patterns.
                                    But there is much more possible with Processing you can program all kinds
                                    of patterns. Which can then be output as a vector graphic.
                                    here a link:
                                    https://openprocessing.org/browse/?time=anytime&type=all&q=voronoi#
                                    • L Offline
                                      The application of shape effects has been fixed, and the efficiency is incredibly high. Thank you!
                                      Halftone can now perform Area Halftone and Blend Halftone as well, with a speed that is a hundred times faster than the previously used VBA macro. I am grateful beyond words.
                                      The Offset Halftone is almost there, but the scaling effect of an individual shape at different grayscale positions is not yet achieved, similar to the effect of width lines.๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                                        An example file for this might help.
                                        • L Offline
                                          https://www.vectorstyler.com/forum/assets/uploads/files/1711824219187-offset-halftone-fill-vs.pdf
                                            @Li-Xiao Is there a vstyler file for this? or was this done in an other app?
