    Regarding the halftone repeater types
    76 Posts 6 Posters 204.6k Views 4 Watching
    • L Online
      Li Xiao @Subpath
      @Subpath Yes, Repeater is incredibly powerful. However, it lacks a non-destructive expansion feature. Currently, image and gradient-based generation can only be overlaid with shape effects after expansion. It would be great to have non-destructive expansion added to Repeater as soon as possible.
        VectorStyler @Li Xiao
        @Li-Xiao said in Regarding the halftone repeater types:
        How would this work? If the repeater is expanded, and the individual object copies can be modified, then it is destructive.
          fde101 Global Moderator
          Vectoraster is another app that is great for this, if you happen to be on a Mac.
          Not free, but it is a one-time payment.
          • L Online
            Li Xiao @VectorStyler
            Non-destructive expansion, similar to virtual expansion, allows the results generated by Repeater to be reflected within the layer and remain in an editable state. This enables shape effects to be applied to the objects after virtual expansion. It doesn't require modifying individual objects after expansion; it's just to allow the application of shape effects to the overall object. Is there a way to achieve this type of expansion?
              In the Repeater panel menu: enable "Apply Shape Effects"
              • L Online
                Li Xiao @fde101
                @fde101 Thank you. I don't have a MAC, but I have explored Vectoraster on its website, and everything it can do, VS can do as well.
                • L Online
                  I have tried enable "Apply Shape Effects," but it doesn't work for the results of gradient and image generation. That's why I asked if there could be a non-destructive expansion feature.
                    Can you send me an example where it does not work?
                    The gradients and images of course are not distorted (by shape effects).
                    For these you need image effects.
                    • L Online
                      @VectorStyler Just as shown in the image.
                        @Li-Xiao Send me the file with the original repeater (first image).
                        • L Online
                          example
                          0_1711881513153_Apply Shape Effects.vstyler
                            @Li-Xiao There is a bug here, I will try to fix it ASAP.
                            L 3 Replies Last reply Reply Quote 1
                            • L Online
                              @VectorStyler Thank you, it turns out it was a bug. I had mistakenly thought it wasn't supported, which is why I was wondering if there could be a non-destructive expansion feature.
                              • L Online
                                Halftone based on the corresponding grayscale values according to the area size. I used four objects as an example, because performing calculations on multiple objects in CD's VBA is too slow.
                                0_1711908024378_Area Halftone.pdf
                                I tried using Repeater but couldn't achieve it. You can watch a video demonstration.
                                https://youtu.be/BRDstB4hbFs
                                • L Online
                                  There are many small apps available that can create wave halftones. I have selected three for your reference.
                                  1. SquiggleDraw
                                    SquiggleDraw will create a SVG file from an image, using the brightness to change the amplitude of sine waves.
                                    SquiggleDraw is free and unencumbered software released into the public domain.
                                    https://github.com/gwygonik/SquiggleDraw
                                    Recorded video
                                    0_1712504072373_SquiggleDraw.svg
                                  2. Makelangelo
                                    Makelangelo Software is a Java program that prepares art for CNC plotters. It was originally designed for the Makelangelo Art Robot. It runs in Windows, OSX, and several flavors of linux.
                                    Makelangelo is free too.
                                    https://github.com/marginallyclever/makelangelo-software/
                                  Recorded video
                                  0_1712504704342_Makelangelo.svg
                                  1. DrawingBotV3
                                    DrawingBotV3 is a software for converting images to stylised drawings with many applications including Pen Plotter Art, Digital Artwork, Image/Video Stylisation, NFT Creation, Embroidery and Graphic Design. With an intuitive User Interface allowing both Beginners and Advanced users to create beautiful artwork without any programming knowledge. Featuring over 50 in-built styles which are all highly customisable, the possibilities are endless!
                                    There are two versions, Free and Premium. I previously purchased the Premium version.
                                    The Free version is Open-Source
                                    The Premium version is Closed-Source
                                    Both versions are available for Windows, Mac and Linux.
                                    https://github.com/SonarSonic/DrawingBotV3
                                    Recorded video
                                  0_1712506173040_DrawingBotV3 - Hatch Sawtooth.svg
                                  0_1712506181339_DrawingBotV3 - Hatch Circulaar Scribbles.svg
                                  BoldlineB VectorStylerV 2 Replies Last reply Reply Quote 2
                                    Boldline @Li Xiao
                                    @Li-Xiao I appreciate all the testing and experimentation you've been doing with the repeater tool in VS. It's such a powerful tool and I can imagine how much better it will be when the improvements listed in the roadmap for repeater are implemented. No doubt your hard work will pay off and hep expand what repeater is capable of
                                      @Li-Xiao Interesting patters. There will be a bit of improvement regarding this in the next build.
                                      L 2 Replies Last reply Reply Quote 4
                                      • L Online
                                        Blend Halftone is a halftone effect that blends two shapes together. One shape corresponds to 0% grayscale value, while the other shape corresponds to 100% grayscale value. The shapes in between blend to represent grayscale values from 1% to 99%. If multiple shapes are blended, each shape corresponds to its respective grayscale value based on the blending proportions.
                                        0_1712564707579_Blend Halftone.pdf
                                          Subpath @Li Xiao
                                          @Li-Xiao
                                          looks interesting and "DrawingBot" too !
                                          btw like to contribute something to this which is Nodebox
                                          related. It cannot compete with either DrawingBot or the Repeater.
                                          I found out that NodeBox also allows to do some things along
                                          those lines.
                                          This works because you can create your own nodes in NodeBox.
                                          With the Python program language and expand the Nodes command set
                                          this way.
                                          John from the NB Forum support team created an image node
                                          which can be downloaded here this Link shows also some Results.
                                          http://support.nodebox.net/discussions/show-your-work/400-image-node
                                          here a example
                                          • L Online
                                            Li Xiao @Subpath
                                            @Subpath The image nodes in Nodebox are also fascinating. Drawingbot also has a node-based version, currently in its Alpha phase.
