    Can't move combined selection
    24 Posts 4 Posters 41.6k Views 4 Watching
    • AyoA Offline
      Ayo @Subpath
      @Subpath Sorry!
      'Two objects selected' than
      • AyoA Offline
        Ayo @b77
        @b77 Exactly what I am doing.
        Can it be a wrong setting somewhere?
        Not familiar with 'recordid' but wil try to make a recording as well.
          Subpath @Ayo
          @Ayo said in Can't move combined selection:
          @Subpath Sorry!
          no problem
          i just saw in your example that your Objects had
          not the same color, which would be the case if
          you combine them
          so i though that you just mean selected, but was unshure
          • AyoA Offline
            Ayo @Subpath
            @Subpath said in Can't move combined selection:
            not the same color,
            The gray is intended as the echo or imprint on the burial shroud of the moved item.
              b77 @Ayo
              @Ayo Use RecordIt or some other screen recording app β€” it's much faster
              than having to take screenshots, combining them and writing explanatory
              text over them. πŸ‘
              And when the file is more complex (not this case here) attach the file as well.
              • AyoA Offline
                Ayo @b77
                @b77 said in Can't move combined selection:
                text over them.
                Did my best, downloaded Recordit but my recordings gives grey empty screens.
                Again something to solve.
                  b77 @Ayo
                  @Ayo If on Windows: Subpath had only good things to say about ScreenToGif
                  AyoA S 2 Replies Last reply Reply Quote 0
                  • AyoA Offline
                    Ayo @b77
                    @b77 On Mac
                    Didit!
                    Had to toggle a switch in System Settings, Privacy & Security.
                    Here my first recordingπŸ˜ƒ but doesn't solve the problem: https://recordit.co/BbYZq7vnvt
                      Subpath @b77
                      can only repeate my praise πŸ™‚
                      ScreenToGif ( Win only) is a very small screen recorder (only 170 kb)
                      with features you won't believe, especially at this size
                      I often use it for longer screen recordings
                      because Recordit sometimes refuses to upload
                      Then I play the recording with Screentogif and
                      use Recordit to record that. Because Recordit stores
                      the record online, which Screentogif doesn't do
                        Subpath @Ayo
                        @Ayo
                        Here my attemp, work as expected
                        Win 10, VS 1.2 Beta
                        Here the Video
                        • AyoA Offline
                          Ayo @Subpath
                          @Subpath @b77
                          About your recordings: you both can do amazing things that I can't do.
                          Glad my classic textbook explanation still works. Advantage over Screen Recording is the exercise in VS. Working with, text, arrows etc. (For example, I notice that during my explanation the text cursor in the text boxes does not always want to appear. But that is an other issue.)
                          • AyoA Offline
                            Ayo @Ayo
                            Not complex, but attach the file anyway.
                            0_1698330009516_Move2.vstyler
                            S b77B L 3 Replies Last reply Reply Quote 1
                              Subpath @Ayo
                              @Subpath @b77
                              No problem, explain it with whatever you feel comfortable with
                              When it comes to screen recording, sometimes it's just easier
                              to figure out what someone actually does
                              By the way, I only started screen recording when I started
                              posting questions about VectorStyler in this forum.
                              I never needed it before.
                                Subpath @Ayo
                                tried it with your file
                                everthing works as expected
                                Here the Video
                                  b77 @Ayo
                                  @Ayo Moving or duplicating the two black shapes in the file works here as it should.
                                  No idea what is causing this. Maybe you're using a stylus and not a mouse or trackpad?
                                  OK, you're on a Mac.
                                  You can try to move the two files (settings.xml and workspace.xml) somewhere else:
                                  • close VS
                                  • switch to the Finder
                                  • click the 'Go' menu > Go to Folder…
                                  • paste this: ~/Library/Application Support/NumericPath/VectorStyler1.2/vector/data/resources
                                  • press Enter/Return.
                                  • move these two files (settings.xml and workspace.xml) outside that folder.
                                  Then you can start the app again and see if the issue is solved.
                                  If it's solved, send the .xml files to the developer's email (csraba at this domain).
                                  • L Offline
                                    Li Xiao @Ayo
                                    @Ayo Tested it and there are no issues. Try clicking on "Restore Defaults (Help\Restore Defaults)" and then test it again.
                                    • AyoA Offline
                                      Ayo @b77
                                      @b77 Using a mouse.
                                      Followed your procedure and problem is solved Indeed!
                                      Still annoying that that happens.
                                      Will send the .xml files to the developer's email.
